Go to Post For those of us in the north, a water game turns into an ice game, which becomes Lunacy. And I don't think any of us want that. - Kimmeh [more]
Unread 17-02-2006, 03:01
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
Digital inputs in autonomous mode?
I've noticed that we have pwm and relay set to 127 and 0... but nothing set for digital, will digital inputs work during the autonomous?
I mean can I go ahead and say:
if(!rc_dig_in12)
DestoryPlanetEarth();
Also, one more question: I don't have a switch box built for the Competition port... yet... Is there a way I can enable the autonomous mode through a button on a joystick?
Thank you for your help in advance!
Unread 17-02-2006, 06:37
aaronm_k aaronm_k is offline
aaronm_k is on a distinguished road
Re: Digital inputs in autonomous mode?
if(!rc_dig_in12)
Digital controller inputs (such as rc_dig_in12) will work in autonomous mode, as they are plugged directly into the RC. Digital OI inputs, on the other hand, will not work as the OI is disabled during autonomous mode.
If you want to simulate autonomous mode using a joystick button, open main.c and change line 52 to:
if (autonomous_mode || p2_sw_top)
and open user_routines_fast.c and change line 105 to:
while (autonomous_mode || p2_sw_top)
where p2_sw_top is the joystick button you want to use.
Unread 17-02-2006, 14:10
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Make sure to remove that before competition, you don't need your drivers accidentally enabling autonomous
Matt Krass
Unread 17-02-2006, 14:40
CarpeDiem CarpeDiem is offline
FRC #0135
CarpeDiem is an unknown quantity at this point
If you dont have the box built for entering auto then you can just turn the theam number to 1 i think to enter auto mode.
Unread 17-02-2006, 21:50
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
You could just take a small piece of wire, strip the ends, and connect the auto and ground pins. I forget which is which, but it is in the manual
void function(void)
  function();
Unread 18-02-2006, 07:46
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
0, actually. But yeah, that'll work.
Unread 18-02-2006, 13:04
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Because the competition port pins are hooked directly up to the PIC inside, IFI recommends (in one of their documents, forget which) that instead of hooking your wires directly to the port, you should insert a resistor on one leg. Sounds like good advice to me...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 18-02-2006, 13:13
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
What would that do? We just have them connected.
Unread 18-02-2006, 13:16
If you accidentally touch the wrong pin, say a +5 to GND, it would prevent you from frying the chip. (for example)
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
