Go to Post "FIRST, molding the future of America by inspiring children in the fields of science and technology....and eliminating playground dodgeball forever." - Andy Grady [more]
Unread 17-02-2006, 19:03
BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
Exclamation HELP! We need pneumatic wiring help!
Our electrical/ programming team is basically completely new this year and we have no clue what so ever as to how to wire an SMC valve (The one that will stop halfway through the stroke). We desperately need detailed instructions on how to do this. We've looked at other posts, and we just cannot figure it out. Please help! Ship is way too close for this! We really need anyone's help, ASAP.
Please, we're begging you!
I have a higher and grander standard of principle than George Washington. He could not lie; I can, but I won't. -Mark Twain
Unread 18-02-2006, 00:24
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: HELP! We need pneumatic wiring help!
Which SMC valve are you referring to? I'm not aware of any valve that is in the kit that can stop halfway through a stroke. If you need two positions the easiest way (in my opinion) would be to use two pneumatic cylinders on different valves.
I'm not exactly sure what you're asking, however, could you provide more information please? Thanks.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 18-02-2006, 00:39
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Hmm I believe you mean the double solenoid? You wire each of the red wires to the M+ and M- on the spike and the two black wires to the ground.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 18-02-2006, 01:12
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Yes the above post is correct, however this valve alone isn't enough to stop a cylinder stroke midway. You should use another double solenoid valve so that one valve controls the air into the cylinder and the other valve controls the exhaust. You see you need to lock the air in the exhaust side to stop the cylinder mid stroke. Check out this post:
http://www.chiefdelphi.com/forums/sh...ght=pneumatics
Post #11 has a simple diagram that shows you how to do it.
Good luck!
Unread 18-02-2006, 07:44
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Good luck!
This is how CHAOS has done it in years past with positive results.
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 18-02-2006, 08:50
Good luck!
I'm pretty sure that this valve alone is enough. We had it on the bench and we were stopping the piston halfway through with the orange buttons.
Unread 18-02-2006, 08:54
OK, I'm going to show my ignorance. When you say each, does one red wire go to positive and one go to negative? And the black to ground, exactly where do you attach it, to M-? to the fuse block? Sorry, I'm just not sure what to do!
-Brittany
Unread 18-02-2006, 12:45
Imaginary Friend
AKA: Kevin Li
Team Role: Student
-Brittany
Yes, one red wire is going to M+ the other will red wire will go to M-, the Black Wires you can connect to the ground on the fuseboard.
Kevin Li
596 - Sciclones
Unread 18-02-2006, 15:44
Thanks a lot.
Unread 08-03-2006, 08:44
Suicidesurfer Suicidesurfer is offline
FRC #0075
Suicidesurfer is an unknown quantity at this point
If you wanna know anything about pneumatic contact this screen name: pielesuave....he is on team 75 and will be able to help you
Unread 08-03-2006, 17:29
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You need two valves. One for direction, which you hook up normally. Then you connect the vents from the first valve to a second, to stop the air from venting to the atmosphere. This stops the cylinder from moving until this second valve is opened.
Program the first for direction, the second for movement(on/off)
Unread 09-03-2006, 19:17
DonRotolo's Avatar
Back to humble
FRC #0832
This will work fine. Last year we found a better solution, called a "Three-position pressure center" valve. The spec sheet is here. Look at valve type SY3520-6H, for example.
This kind of valve has three positions, and uses two solenoids: Position 1 is extend, Position 2 is hold, and Position 3 is retract. One solenoid is Extend, the other is Retract, and when neither is energized it means Hold. (This can and should be controlled with a single spike as explained by coffeeism above).
We selected "Pressure Center" types, which apply full pressure to both sides of the cylinder when in the Hold position. You can also choose "Closed Center", which closes off all air to the cylinder. You don't want "Vent Center", which will allow the piston to move freely in the "Hold" (center) position.
One important thing we learned last year: Pistons work best in 'this end or that end' applications - they do not work well for non-endpoint positioning. The problem is that any variation in load causes the piston to move, because it's only air, and that will often cause a problem.
Good luck. I hope this post helps anyone considering midpoint positioning of pneumatic cylinders.
Don
Unread 09-03-2006, 23:08
AKA: Dan
Don
Whoa! Correct me if I'm wrong, but I thought the use of "alternative" solenoid valves is prohibited! How'd you get away with that? Of course there are valves out there that can control mid-stroke positioning, but we are only allowed to use the solenoids in the kit. You are right, though, that the compressability of air makes positioning pretty iffy...definitely no precision there without a more complex feedback mechanism (such as a pot).
Unread 10-03-2006, 09:26
I thought the same, but a quick search of last years rules seems to allow it.
I will disagree about the positioning, however. We used it to lift our main arms last year, and it worked well enough to seed 1st at VCU and 2nd NJ Fast, strong, simple and precise enough to lift and position the tetras.
However everything has a place, and this year we use no pneumatics.
Wiring the robot in inventor. vVigglEs Inventor 15 06-03-2006 11:35
pneumatic rules ? mcktim Rules/Strategy 2 29-01-2006 13:59
Pneumatic Gripper ruling Nitroxextreme Pneumatics 7 30-01-2005 13:04
pneumatic wiring nick_champ_2 Electrical 3 23-02-2003 01:21
pneumatic wiring nick_champ_2 Electrical 0 17-02-2003 18:28
