Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 17-02-2006, 20:52
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: even simple autonomous code doesn't work??
Originally Posted by Salik Syed
ummm... printf does not run during autonomous ! i would suggest building a dongle, look up white papers on how to do this... its fairly easy... if ur in a hurry grab one of those 13pin (?) competition port size cable plug it in and short the right wires
A generalization like is silly, I've run printf's in autonomous, you simply need the stdio.h present.
It's been my experience that setting the team number to 0 does induce autonomous, but without an OI attached the robot remains disabled, so the motor outputs are blocked, just like regular disabled mode. You're better off connecting the OI and building the dongle, it takes fifteen minutes or so.
Matt Krass
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Where to insert code Autonomous mode caderader Programming 5 18-02-2005 16:49
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
