Go to Post I believe in the rookie teams. - Arefin Bari [more]
Unread 12-02-2006, 15:59
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
How fast can your robot shoot?
Team 1675 was having some fun Saturday and we loaded a 10 foot tube up with 15 poofballs. We shot them all in about 4 adn a half seconds. Thats are record......whats yours? I'll try to get a video up soon.
Last edited by Joe_Widen : 12-02-2006 at 16:10. Reason: Didnt want to double post.
Unread 12-02-2006, 16:13
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Lightbulb Re: How fast can your robot shoot?
we shot around 4 balls a second (16 balls over 4 seconds). I'm not on our manipulations team, but that's the fastest I saw it go. Mind you that the feeder fed the balls that quickly. On the robot, it can shoot about 10 balls in 2 1/2 to 3 1/2 seconds.
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 12-02-2006, 16:20
MARS-CJ's Avatar
MARS-CJ MARS-CJ is offline
AKA: Carl Jalm
FRC #1523 (M.A.R.S.)
Team Role: Scout
MARS-CJ is on a distinguished road
Send a message via AIM to MARS-CJ
Ours wasn't as fast as yours...
Here's a vid: (also posted in this thread)
http://marsbot.org/files/shooting.wmv
"Yes, I've gone where no man has gone before, but... I was in Mexico and her father gave me permission!" - William Shatner
Unread 12-02-2006, 16:24
Joe_Widen's Avatar
That is definately the neatest looking robot I've seen this year. How did you guys get it to do that. It looks like you had a high torque motor and a surgical tubing rig. That looks really good, except how do you plan to get more balls into the feeder, are you going to bend some aluminum and make it like a slide of some sort?
Unread 12-02-2006, 18:02
Team ERV's Avatar
Team ERV Team ERV is offline
FRC #0204
Team ERV is on a distinguished road
wow guys that looks pretty awesome....but does it come under that rule with the projectile?
Unread 12-02-2006, 18:28
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
For all our balls to go the same distance, we need ~1/2 second between balls (might be slightly more now, gearing was changed). We figure with constant tracking this is fine though, especially since I don't see us storing 80 balls we need to launch at once.
Unread 12-02-2006, 19:13
Nate Laverdure's Avatar
FRC #2363
Oh, that's an easy question. Ours shoots as fast as the balls can get to the shooter.
Seriously, I'm not sure how many balls it can shoot in whatever time limit. What I do know, though, is that the tangential velocity of the shooting wheels is about 80 mph. The ball gets shot through the wheels at 60 mph (there's some slippage), then it goes through a vertical tube to our turret which slows it to more or less 28 mph.
Unread 12-02-2006, 19:28
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
You guessed right on how it works, but we are planning on using a hopper of sorts (hint: basketball) to allow human loading as well as a small ammount of onboard storage.
I don't know what rule you are talking about in particular, but the only rule we were concened about was about stored energy. This problem was eliminated as the surgical tubing pulls the arm back to the point of lowest energy.
That sounds very impressive. I would love to a video of it in action! How long is the delay between balls for accuracy; none?
Unread 12-02-2006, 19:52
Joe_Widen's Avatar
Our launcher can shoot as fast as we can load them also. Once we get to around the 10th or 11th ball, they start to shoot a bit shorter(the 15th ball we shot in the four second span hit the ground at 26 ft from the shooter). Also its very accurate. Good Luck to everyone and ill try to post some pictures or videos tomorrow.
Unread 16-02-2006, 11:00
RebelWithARobot RebelWithARobot is offline
FRC #0931
RebelWithARobot is a name known to allRebelWithARobot is a name known to allRebelWithARobot is a name known to allRebelWithARobot is a name known to allRebelWithARobot is a name known to allRebelWithARobot is a name known to all
i believe we will be firing around 10 balls per second
Unread 16-02-2006, 12:13
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I'm hoping we shoot balls under the speed limit.
It was spinnin' pretty darn fast the other night.
Unread 16-02-2006, 15:24
Nita's Avatar
Nita Nita is offline
^_^
FRC #1190 (Anonobots)
Nita is just really niceNita is just really niceNita is just really niceNita is just really niceNita is just really nice
I believe that our robot can shoot at least 10 balls per second, but we probably won't be doing that at the competition because well... it is very possible for BAMFR(our robot) to shoot 2 balls at the same time!
Unread 17-02-2006, 17:39
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
on Friday we finally got our spiral integrated with our shooter. WE were pulsing the motors and got a ball per second. I believe that we shot two, waited one, shot two, etc. Id be interested to know a) how accurate that team that shot 15 in 4.5 seconds actually had and b) how much the distance was drastically changed. Loss of energy is not a good thing. Did those balls just flop out? Or did they shoot almost as well as the first one.
Unread 17-02-2006, 21:05
natis's Avatar
natis natis is offline
natalia
AKA: natalia soberanes
FRC #0987 (High Rollers)
natis has a spectacular aura aboutnatis has a spectacular aura aboutnatis has a spectacular aura about
Send a message via MSN to natis
video
Ours is working pretty good and fast!!
check it out!
Unread 17-02-2006, 21:52
Joe_Widen's Avatar
Ours didnt chage very drastically between the first and 15th ball. The only change was maybe 5 feet so i think were in good shape. Especially since we have an almost fool proof spreadsheet made by out GE mentor. Good Stuff. I dont have it with me so I can't upload it, but it makes robots alot less complex.
Pre-Rookie Teams - The How To Keith Chester General Forum 6 17-09-2008 00:28
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
How fast will your robot be? Anton Abaya General Forum 18 20-01-2002 22:26
