Go to Post Our "gracious professionalism" credo insists that we make decisions that are based solely on the desire to inspire and recognize science and technology using robot construction and competition as a vehicle. - Al Skierkiewicz [more]
Unread 17-02-2006, 21:50
revolution1737 revolution1737 is offline
Robot Overlord
FRC #1691 (Revolution1737)
revolution1737 will become famous soon enough
Trig problems
I have tried Kevin Watson's trig code with the eeprom, a cordic approach (team 226's code i think), and the default sin function in math.h and every time I come out with a wrong value when I print. I usually get 16512 or 0. I have tried switching from radians to degrees. Am I just getting unlucky or is there something I'm missing?
float meh;
angle = sin(3.14);
printf("the angle is = %d\r\n",meh );
Unread 17-02-2006, 21:53
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Re: Trig problems
Well, it might do some good to actually assign meh a value. Either that or printf angle, instead of meh. [/sarcasm]
void function(void)
  function();
Unread 17-02-2006, 21:54
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Trig problems
I can't vouch for the specific code you're using, but make sure that your sin() function actually wants an angle in floating point radians. Many take integers, as floating point is many times slower...
If this isn't the problem, posting the code you're using will help greatly
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 17-02-2006, 21:57
Robot Overlord
Re: Trig problems
float meh;
angle = sin(3.14);
Stupid me
float angle;
angle = sin(3.14);
printf("the angle is = %d\r\n",angle );
[/quote]
There, I think...
Unread 18-02-2006, 00:01
Re: Trig problems
You're trying to print a float value as an integer (%d)
Unread 18-02-2006, 00:07
Re: Trig problems
Speaking of that, the printf doesn't even support floating point (%f). You'll have to do something like multiply your result by 1000, cast to int, and print that.
Unread 18-02-2006, 00:31
Re: Trig problems
Yea, you can always manipulate the value to print it.
E.g.,
#define ACCURACY 1000 //How many decimal places are important to you
float f;
int i, i2; // Might need to be longs if you have a lot of significant digits
f = 245.56;
/* Print float value */
i = (int) f;
i2 = (int) ((f-i)*ACCURACY);
printf("f = %d.%03d \r", i, i2); //e.g., f = 245.559
Unread 18-02-2006, 01:23
Robot Overlord
Re: Trig problems
E.g.,
float f;
f = 245.56;
i = (int) f;
I wish I had taken a class so I knew C. Could you write it so it takes the value in degrees from get_gyro_angle() and uses it in a sin function. I have spen 9 hours (seriously) and I still cannot get the right value. Any help is greatly appreciated.
Unread 19-02-2006, 01:09
teh_r4v3 teh_r4v3 is offline
AKA: Rajeev Sharma
FRC #1511 (Rolling Thunder)
Team Role: Student
teh_r4v3 is on a distinguished road
Send a message via AIM to teh_r4v3
Re: Trig problems
First off, remember that the sin function is not part of the standard library, so you'll have to add it in yourself. Also, it takes radians, not degrees. On top of that, the PIC processor the IFI RC uses doesn't have a FPU (floating point unit), so it has to emulate one in software. (In other words, doing anything with decimals is reeealy slow.) So what I'm going to write isn't exactly the most optimized code in the world.
Going off of Mark's code, this should work:
#define PI 3.14 //Pi to however many digits you want
float f;
f = sin((float) get_gyro_angle() / (2.0 * PI));
i = (int) f;
Rajeev Sharma
Team 1511 Rolling Thunder
hoojamomma?
speed of math.h trig functions? Jared Russell Programming 4 07-02-2006 07:13
Anyone Else Having Problems with Q&A on FIRST? Windwarrior General Forum 6 25-01-2006 10:54
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Radio problems -- not archiver 2000 1 23-06-2002 22:23
