Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Unread 17-02-2006, 22:56
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Pot Printf Variable
Hey guys, just got a quick question. I have a command to tell me the range of our potentiometer. Its a printf command. I have gotten the adc code all up in the code already. It goes something like:
printf("Pot value: %d\r\n", variableNameUsedForPot);
Except, Im not sure what the actual variable name is. Can someone maybe tell me real quick I cant find it in the code. Thanks!
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 17-02-2006, 23:00
Bob Koehl Bob Koehl is offline
Engineer
no team (The MEZ)
Bob Koehl is a jewel in the roughBob Koehl is a jewel in the roughBob Koehl is a jewel in the rough
Re: Pot Printf Variable
See this example from the IFI programming guide (2004-programming-reference-guide-12-apr-2004.pdf) page 16:
/* Example of using the Analog Inputs to map an analog input to a PWM output. */
unsigned int sensor1;
unsigned char sensor1_8bits;
sensor1 = Get_Analog_Value( rc_ana_in01 ); /* Assign the analog reading to a variable. */
sensor1_8bits = (unsigned char)(sensor1 >> 2); /* Only take the 8 most significant bits, */
pwm01 = sensor1_8bits; /* because PWM OUTPUTS can only be 8 bits. *
would be
printf("Pot value: %d\r,(int)sensor1);
Hope this helps.
Bob Koehl
Michigan Engineering Zone Mentor
VP/Secretary DADARA
Unread 17-02-2006, 23:55
FRC #1706
Team Role: Driver
So pretty much I can do
then in proccess_data_from_master_up we put the
would that work, and would the top part go into adc.h or adc.c?
TEAM 1706
Unread 18-02-2006, 07:17
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
You should place the sensor declaration whereever you are going to be using it. If it needs to be in multiple places, put an extern declaration in a header file which you then include in the extra files. IE:
externDeclartion.h (or whatever you want to call it)
extern unsigned int sensor1;
someFile.c
#include "externDeclaration.h"
--EDIT--
And yeah, you have the idea.
Unread 18-02-2006, 10:48
kevlarman kevlarman is offline
"why cant i install Linux?" guy
AKA: Roman Tetelman
None #0100
kevlarman is an unknown quantity at this point
if you have kevin watson's adc code set up then you should use Get_ADC_Result(1) instead of Get_Analog_Value( rc_ana_in01 )
printf could not find definition Alex829 Programming 7 27-06-2005 10:04
Printf Oddity : Programming Challange DarkAlex Programming 7 21-03-2005 08:12
printf statements do not display in autonomous mode PVC Pirates Programming 3 22-02-2005 15:41
Anyone with a replacement Printf? Larry Barello Programming 5 19-03-2004 02:20
