Go to Post Push the envelope a little, but not too much. There's a difference between being on the cutting edge and being on the bleeding edge. - cadandcookies [more]
Unread 17-02-2006, 20:46
FRC #0701 (RoboVikes)
What constants are u using for high velocity PID
What constants for P I and D? I got it to somewhat work but its velocity was always too high... i know i could further test more values but i tried all day and now i am at home and have no access to the robot, i desparately need some values that i can try out... our custom PID code is totally screwed up and i might port over watsons but i need a start point well...... this turning into a rant...
thanks for any help
Team 701
Unread 17-02-2006, 23:28
President, VEX Robotics, Inc.
Re: What constants are u using for high velocity PID
Try tuning it without I. A PD loop will be fine for high speed velocity. You are, more than likely, getting fast Integration error build up. We are not using I and we are right on target for both wheels. At high speed, the P gain is very sensitive so you will need to really play with D a lot more than if you were tuning a drive train.
Unread 17-02-2006, 23:29
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Also make sure that your terms are sensible - I had problems when my P term overflowed when the error was large enough. If the signs are wrong, then you'll find all kinds of problems...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 18-02-2006, 23:22
Jared Russell's Avatar
Taking a year (mostly) off
I had a P of 70, a D of 30, and an I of 3, all divided by a divisor of 10. That's with a 16 CPR encoder on the shaft.
Snaps right to the setpoint.
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Problems Using PID for Velocity Astronouth7303 Programming 6 10-02-2006 09:00
Manual Velocity PID, anyone successful? Chris_Elston Programming 20 31-01-2006 20:51
PID Control Chris Bright Programming 9 26-03-2005 19:44
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
