Go to Post A sign of character is the ability to move on and make the best of what you have, even if you feel you were completely wronged. - Cory [more]
Unread 17-02-2006, 20:11
colman77
Posts: n/a
even simple autonomous code doesn't work??
OK so autonomous mode doesn't seem to have control of the robot...
We are putting our robot into autonomous mode by setting the tean number to 0 on the OI, yanking out the tether cable, and resetting.
We know that it's running the autonomous function in user_routines_fast.c, because we can put a printf in there and it'll print.
However.
If we put ANY statement controlling the pwm's-- no matter how simple-- our victors refuse to do anything but blink orange.
Even if we put
pwm01 = pwm02 = pwm03 = pwm04 = 255;
LIGHTS DON'T CHANGE... and if we hook a fan up to any of them, it doesn't spin.
Any ideas? The lights on the victors DO change when you're in autonomous, right?
Unread 17-02-2006, 20:43
FRC #0701 (RoboVikes)
Re: even simple autonomous code doesn't work??
However.
Even if we put
ummm... printf does not run during autonomous ! i would suggest building a dongle, look up white papers on how to do this... its fairly easy... if ur in a hurry grab one of those 13pin (?) competition port size cable plug it in and short the right wires
Team 701
Unread 17-02-2006, 20:52
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
A generalization like is silly, I've run printf's in autonomous, you simply need the stdio.h present.
It's been my experience that setting the team number to 0 does induce autonomous, but without an OI attached the robot remains disabled, so the motor outputs are blocked, just like regular disabled mode. You're better off connecting the OI and building the dongle, it takes fifteen minutes or so.
Matt Krass
Unread 17-02-2006, 21:11
whoops... my bad... yeah you could definitely run printf during autonomous... but by default it is not included so maybe thats an indication that ur not really in autonomous mode... thats what I should've said...
Team 701
Unread 17-02-2006, 23:58
See if this persons solution helps you.
http://www.chiefdelphi.com/forums/sh...05&postcount=4
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Where to insert code Autonomous mode caderader Programming 5 18-02-2005 16:49
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
