Go to Post All this is sounding like gobbly-de-gook but it is important to understand this gobbly-de-gook. - ebarker [more]
Unread 18-02-2006, 11:11
kevlarman kevlarman is offline
"why cant i install Linux?" guy
AKA: Roman Tetelman
None #0100
kevlarman is an unknown quantity at this point
Re: The silly syntax errors that won't go away!
actually the more traditional way to do that is
#ifndef _MY_HEADER_FILE_H_
#define _MY_HEADER_FILE_H_
//other stuff in the header goes here
#endif
and make sure that all variables are declared extern (and initialized in the .c file that owns them), otherwise each file will get its own copy of the variable.
EDIT:
forgot to mention that _MY_HEADER_FILE_H_ should be the name of the file it is in (in this case it would be myheaderfile.h), if two files have the same #define at the top, one will get ignored
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Union Errors in AutoCAD indieFan Inventor 4 16-07-2004 12:54
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Specs full of errors??? Simon G Motors 1 20-01-2003 12:53
