Go to Post In my opinion, if it can light a fire in your heart to burn with passion, and you can maintain that fine line between passionate and crazy; then go for it. Power to Passion. - RKElectricalman [more]
Unread 17-02-2006, 22:04
FRC #0701 (RoboVikes)
Urgent help needed... Structs and compiling issues
okay so i make a simple structure like this:
struct constants
int KP;
int KI;
int KD;
int div;
then reference it here:
struct constants pid[2]={{0,0,0,0},{0,0,0,0}};
this works fine and dandy but when i do this it gives me a linker error:
struct constants pid[4]={{0,0,0,0},{0,0,0,0},{0,0,0,0},{0,0,0,0}};
What is going on I CANNOT figure it out! the linker says something like this:
idata_pid.o cannot fit the section. Section "idata_pid.o" length = 0x0000010a
please help...! i can't figure it out ... this is so simple yet frustrating
Team 701
Unread 18-02-2006, 11:39
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Re: Urgent help needed... Structs and compiling issues
It sounds like you are using too much memory.
Try making the variables smaller like a short int or an unsigned char
Unread 18-02-2006, 12:07
thats what i thought of as well... but doesn't a char take just as memory as an int ? i will try it though... i don't see why though... i mean watsons struct has 6-7 ints... maybe i have too many we'll see ... thanks
Team 701
Unread 18-02-2006, 13:18
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally Posted by Salik Syed
but doesn't a char take just as memory as an int?
A char is 8 bits and an int is 16 bits when the MCC compiler is used.
Unread 18-02-2006, 14:28
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
...this works fine and dandy but when i do this...:
...the linker says something like this:
Each module is allowed only 256 (0x100) bytes of data. When you added this declaration to pid.c, you pushed it over the limit by 10 (0x0a) bytes. You might be able to get around this limit by putting the declaration in another .c file, and reference it as an extern from pid.c.
[edit]Woah! post #2048! Sweeeet! [/edit]
Unread 18-02-2006, 20:36
anyone that jubilates over having a post count equal to a power of two is a true nerd.
161 posts until i can celebrate !
Team 701
