Go to Post Truly listening to the wealth of advice around you is so important. Don't work in a vacuum all season long. - OZ_341 [more]
Unread 17-02-2006, 20:49
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Relay Commands
I had some free time tonight and I noticed some people are having problems with relays, usually remembering to set both the corresponding FWD and REV values, so I wrote up a quick header file with commands to set relays forward, reverse or off simply by typing RELAY#_FWD or _REV or _OFF
Examples, setting Relay 1 forward
RELAY1_FWD;
Relay 1 reverse
RELAY1_REV;
Relay 1 off
RELAY1_OFF;
The semicolon is important, I designed it that way to be syntax compatible with C, some IDEs don't like commands without semicolons
Hope this helps someone.
Simply drop in your project and add #include "relays.h" where ever you use it.
Matt Krass
Unread 17-02-2006, 22:08
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: Relay Commands
I forgot to set the reverse to 0 when I first tried. Once you know how it works, getting it to work is not a problem.
My Blog!
Unread 18-02-2006, 01:01
Matt Krass's Avatar
AKA: Dark Ages
Re: Relay Commands
I wrote it to make programming a little simpler, nobody is saying you have to use it or not use it, it's out there if you wish to.
Matt Krass
Unread 18-02-2006, 15:04
lil_longo's Avatar
lil_longo lil_longo is offline
AKA: Brian
FRC #1676
Team Role: Mascot
lil_longo has a spectacular aura aboutlil_longo has a spectacular aura aboutlil_longo has a spectacular aura about
Send a message via AIM to lil_longo
Re: Relay Commands
i no me too
Unread 18-02-2006, 18:00
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
Re: Relay Commands
the RELAY_OFF shouldn't be needed, but then again if you're a noob and the easy C key you were given doesn't work then this will work since it's in a header file.
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 18-02-2006, 18:32
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Relay Commands
Good job. I wouldn't limit the usage of this to "C noobs" either. Everyone can benefit from the readability change from
relay1_fwd = 0;
relay1_rev = 1;
to
RELAY1_OFF;
http://www.mikesorrenti.com/
Unread 18-02-2006, 23:03
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Relay Commands
relay1_fwd = 0;
relay1_rev = 1;
to
RELAY1_OFF;
Hey Mike, wouldn't that be RELAY1_REV?
And of would be relay1_fwd=relay1_rev=0?
Serial Commands on MPLAB tribotec_ca88 Programming 2 24-01-2006 16:26
Can anyone create new commands? Jakenan Programming 5 22-01-2005 21:38
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Voice Activated commands Amber H. Technical Discussion 40 03-11-2002 12:40
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
