Go to Post For years, Dave Lavery couldn't fart without people trying to interpret it as a game hint. - Taylor [more]
Unread 18-02-2006, 18:27
douglass1371 douglass1371 is offline
FRC #1371
douglass1371 is an unknown quantity at this point
Program Build Problem
C:\Documents and Settings\teacher\Desktop\camera\frc_camera\camera. c:30:Error [1027] unable to locate 'stdio.h'
I get this message each time i try and compile this project what can i do to change it
Any help would be greatly appreciated
Unread 18-02-2006, 18:34
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Program Build Problem
Looks like you may be running into the path limitation. The compiler can't handle paths with more than 63 characters, so move it closer to the root of your hard drive...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 18-02-2006, 18:43
FRC #1371
I got the same thing wen i moved it closer
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8722 "camera.c" -fo="camera.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
C:\frc_camera\camera.c:30:Error [1027] unable to locate 'stdio.h'
Halting build on first failure as requested.
BUILD FAILED: Sat Feb 18 18:44:17 2006
Unread 18-02-2006, 18:46
MacFlightSierra MacFlightSierra is offline
FRC #0912 (Iron Lyons)
MacFlightSierra is an unknown quantity at this point
in MPLAB, open your workspace [mcw file], go to Project [menu] -> built options -> project, and in the field labeled Include Path $(INCDIR), insert C:\mcc18\h
that making the assumption you installed C18 in its default diurectory [if not, change that address to your specific C18 folder\h]
good luck
program download problem zdeswarte Programming 5 23-03-2005 06:46
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
Build season wrap up Ryan Albright General Forum 2 24-02-2004 23:17
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
