#16
Re: Got Weight?
Everyone knows the weight of code is really influenced by how many non working sections you have commented out! |
#17
Re: Got Weight?
Robot liposuction Also try trimming bolts that are at unnecessary lengths, it adds up |
#18
Re: Got Weight?
Remove three strands from every wire.
But seriously copper is heavy shorten any excess wire runs and service loops. Also swissing your robot isn't really good for that much weight. You can only get a couple pounds usually. Thinner lexan and narrower diameter pneumatics are also good tricks if you can. |
#19
Re: Got Weight?
Also, smaller/less motors if you can, they weigh a bit. |
#20
Re: Got Weight?
I was told that we're calling in the Orkin Man to debug our code for us - that should take a good deal of weight out.
You'd be surprised what you can put holes in that willl actually benefit your robot's functionality. I can't comment on speed effects really, but in terms of moving balls around... ![]() |
#22
Re: Got Weight?
Re: Got Weight?
You could replace heavy steel sprockets with lightweight aluminum ones.
That might save a few pounds. |
#24
Re: Got Weight?
holes work no matter where you put them.. As long as it isnt in a major compenent ...lol-Pavan |
#25
Re: Got Weight?
We weighed in this morning at the local fruit packing plant. It was 114 lbs. Our robot is having surgery as we speak.
114 was too much as we still have things like shields and bracing to install, battery covers, and part of the hopper. Took off 5 lbs by removing a noncritical part and replacing it with something lighter. WOWOWOW. Diet time. Last years robot was 4 ounces under the 120 limit. Carolyn Hinckley |
#26
Re: Got Weight?
Last year I ordered aluminum nuts and bolts for my team. Bolts, nuts and washers are made of steel which is much heavier than aluminum(about 5x as much). Most bolts and nuts also don't take even close to the load necessary to break or bend them. We didn't build our robot with them, but I took an inventory of the major bolt sizes we used and brought boxes of aluminum replacements to the competitions. Whenever we needed to change a part we optimized it with aluminum parts.
I've also heard of team using plastic hardware which is 1/3 the weight of aluminum and I guess 1/15th the weight of steel. |
#27
Re: Got Weight?
Compressor:
Last year we made a backpack with a compressor and a battery so we could fill the tanks right before each match. It saved us a few pounds. Structure: Re-evaluate your structural design. Chances are you have over-engineered some parts. Can they be replaced with thinner materials? Durable vs. disposable: Can you replace something that is very durable with something that will last you through a match and can then be replaced? Our team uses 1/16" polycarbonate for shielding our robot. Some pieces survive an entire regional unscathed, other pieces need to be replaced every couple rounds. We could have used thicker polycarb and spent less time replacing stuff, but we get a lot more functionality by having a few extra pounds to work with. Of course, if you go the disposable route, be sure it's easy to replace and you have lots of spares. |
#28
Re: Got Weight?
While our robot is made of holes, it is important to remember that you need about 40 1" holes in 1/4" Al to cut out a pound of weight.
So get drilling. ![]() |
#29
Re: Got Weight?
Get on your hands and knees with a file.
#30
Re: Got Weight?
Advice to stay underweight:
Use ligher materials whenever possible, but use metal for things that have to be more robust, such as turrets, drive, and moving parts. Use PVC for nonmoving parts, such as bins. Weigh the parts of your robot, and your robot at each substage of building. Don't use pneumatics. Budget your weight and keep to your weight budget. Remember, design each part with weight in mind. A well-designed, well-built robot should not have to deal with a weight problem. Advice to get underweight if overwieght: Make Swiss cheese (something that's already been said way too much) Don't use more motors than you need. Keep your frame simple. Look for lighter alternatives to what you have. This invovles doing a bunch of research. Remove unnecessary parts |
| Robot Weight Limit: Rule Conflict | Specialagentjim | Rules/Strategy | 10 | 06-08-2005 17:52 |
| Breaker Panel weight | Emily Pease | Electrical | 4 | 24-01-2005 12:22 |
| Robot Part Weight List | Don Wright | Technical Discussion | 3 | 20-01-2005 12:55 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
