Go to Post Now, I either need to convince Mike Martus to start the webhug early (or move it back 1 hour), skip the webhug, miss the first part of the presentation, or just clone myself. - Andy Baker [more]
Unread 18-02-2006, 09:35
DemonYawgmoth's Avatar
DemonYawgmoth DemonYawgmoth is offline
AKA: Artem Kochnev
FRC #1396 (Pyrobots)
DemonYawgmoth is an unknown quantity at this point
Send a message via AIM to DemonYawgmoth Send a message via MSN to DemonYawgmoth
Another question about LEDs on the OI.
We read that we can use LEDs on the OI joystick ports, and when we ripped apart the cable from a joystick from a few years back, we found that there are only 10 wires, for 15 pins. On the 3rd joystick port, there are 4 pins for LEDs, but no wires for them. What would we have to do to connect an LED to this port? Would we have to wire it directly to the pin on the OI? Or is there a way to run another wire or something to the joystick cable? Thanks for the help.
Unread 18-02-2006, 10:17
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Another question about LEDs on the OI.
You will want to get something like that and make a custom connector. LED you hook between the LED Pin and Ground.
http://www.ifirobotics.com/docs/oi-r...e-11-21-05.pdf You will want to reference
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 18-02-2006, 21:51
tpc's Avatar
tpc tpc is offline
AKA: Tom Convery
FRC #0623 (Cougar Robotics)
tpc is on a distinguished road
We used insulation displacement connectors (IDC's) from Black Box. The male connector is P/N FG115 and the female connector is P/N FG110. (They also sell ribbon cable - P/N EY241A - but 100' is probably much more than you need.)
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
A question about control system options computhief263 Control System 7 04-02-2004 14:46
LED's, resistors, computers... ohm my! DanL Electrical 3 01-07-2003 09:37
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
