Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 18-02-2006, 23:13
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Exclamation Camera glitch / failure
I am having a problem with the 2005 camera code and the 2006 controller. The camera will "glitch" randomly and never recover. I have had the thing run for 30 minutes with no problems, and yet sometimes it will give out in five seconds!
It is giving all the appearences of a receive failure, and resetting the RC is the only thing that can make it recover. I have tried 2 different camera boards, with and without the TTL converter (made a special cable for without!). I have tried software and hardware resetting the camera board, to no avail. (It resets the camera board, but the RC never seems to receive anything, including the power-on ACKs, after the failure).
Can anyone help me on this? It is frustrating me to no end. When I say random, I mean random!
EDIT:
I wonder if this will clear up the problem? It looks as if maybe we are setting the RX overflow bit now and them (maybe due to a coincidental firing of a lot of interrupts in a short period of time), and this will halt the RX completely until the following code is called.
Kevin, could you please help me with this? I haven't worked directly with the PIC USARTs before.
if(RCSTA2bits.OERR)
    RCSTA2bits.CREN = 0;		// Make sure the receive is still enabled!
    RCSTA2bits.CREN = 1;
    RXINTE2 = 1;
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 19-02-2006, 11:18
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Camera glitch / failure
EDIT:
if(RCSTA2bits.OERR)
RXINTE2 = 1;
Make sure the serial port receive interrupts are the first to get serviced in the low-priority ISR. If it is an overrun error, you can only fix it by resetting the serial port Rx circuit with this code:
// if the interrupt handler was disabled while data was being received,
// data may have backed-up in the receiver circuitry, causing an overrun
// condition. So let's check the OERR bit to see if this has happened
// and if it has, we'll need to reset the serial port receiver circuitry
// to get data flowing again.
if(RCSTA1bits.OERR)
// reset by turning off the receiver circuitry, then...
RCSTA1bits.CREN = 0;
// ...turn it back on
RCSTA1bits.CREN = 1;
// indicate that we've had an error
RX_1_Overrun_Errors++;
If you're using my serial port driver, this is automatically handled in the Rx ISRs. If you aren't using my code, you can place this code in the fast loop.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-02-2006, 18:43
Eldarion's Avatar
OK, thanks. That worked just great!
It is maddening to waste a few days trying to fix an error that can be fixed by flipping one bit.
-- Thomas Paine
-- Anonymous
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
Camera shows no love to drive motors anifinder Programming 4 13-02-2006 10:31
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
