Go to Post You know, sometimes you people get just a little scary.... - JaneYoung [more]
Unread 19-02-2006, 06:19
nirty's Avatar
nirty nirty is offline
FRC #1574
nirty is an unknown quantity at this point
connect to wires (6WG) togther
I wonder, how i can connect to wires (6WG) without the quick Anderson connection.
Unread 19-02-2006, 09:35
Re: connect to wires (6WG) togther
Nirty,
You need to be a little more specific. On the robot you must follow the wiring diagram in the robot manual and use the connectors and terminals specified. Also check the First Tips and guidlines doc on the First website.
Unread 19-02-2006, 10:48
1574aviad's Avatar
1574aviad 1574aviad is offline
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
1574aviad is on a distinguished road
Send a message via ICQ to 1574aviad Send a message via MSN to 1574aviad
what nirty means is that we want to create a 6AWG extention to for the quick Anderson connector cables...
I heart FIRST
2005- Israeli regional champions
2006-Israeli regional- champion alliance, innovation in control award, entrepreneurship award, woody flowers award
Championship event-14th on Curie, backup #4 on elimination
1574 Rocks
i turned into a mentor
Unread 19-02-2006, 20:30
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
You can buy the Anderson PowerPole connectors and make the cables yourself to any length.
I believe Terminal Supply carries them. I have bought them from Allied Electronics in the past.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 19-02-2006, 21:05
in between teams
AKA: Luke Van Oort
Some inspectors get very particular about this. We use a connector that looks a lot like the ones on the battery, just bigger for two 6AWG wires. Crank it down with a wrench and wrap with tape.
Team 1219: 2009 - Mentor
Unread 19-02-2006, 22:37
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
could someone post link were I can find the connectors I cannot seem to find them
Unread 19-02-2006, 23:14
Marvin and Nirty,
You can splice the #6 with an approved crimp splice (butt splice) made for #6. I see this as introducing another point of failure though and would recommend purchasing additional pins for the Anderson power connector for you local outlet or Terminal Supply. If the butt splice is your only alternative, we would cut off the insulation, crimp and solder the wire and then use heatshrink or electrical tape to solder the joint when cool. Use the added #6 wire in your kit to make the correct length wire. If that doesn't work for you, you can use the smaller fuse panel as a tie point to extend the power wiring to where you need. I would be hesitant to suggest any other method, without making you illegal sometime in the future.
Unread 21-02-2006, 08:53
1574aviad's Avatar
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
well... we delivered our robot and ended up re-wiring a lot of stuff so we won't need any extentions
I heart FIRST
1574 Rocks
How to connect the touch sensor? DemonYawgmoth Electrical 3 13-02-2006 00:29
connect three computers without hub kirov Chit-Chat 9 28-02-2005 18:55
Connect Playstation Controller to PC USB. kirov Control System 1 28-02-2005 08:24
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
