Go to Post People... chill. It is week 1. Recall week 1 last year when many teams said "no one is capping with the 2x ball"... "only a few teams are hanging". - Andy Baker [more]
Unread 17-02-2006, 00:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Epoxy, glue, loctite gear to shaft. Any chance of working?
I need to get a gear affixed onto a shaft. We have broken two of them trying to press fit it. We do not have anybody to TIG weld it. (The best we can do is flux cored wirefeed, and that becomes questionable). Is there any commercially available product that will bond the gear to the shaft? Both gear and shaft are steel and the diameter of the shaft is 3/8" The gear is in a drive system gearbox. Two small CIMs are geared down 12:45 to this shaft on which the gear in question resides.
Unread 17-02-2006, 00:41
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: Epoxy, glue, loctite gear to shaft. Any chance of working?
We use hex shaft and roto-broach(sp?) our sprockets and gears. If you just want to glue it, I would recommend JB-Weld. It is the omnipotent metal epoxy, and probably available at your local hardware store. If you use enough of it and use it right (I.E. scuff all surfaces and clean them well) it might just work.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 17-02-2006, 05:30
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Loctite does make a product that will work. It's called retaining compound and we use it at work for the same thing. On our injection molding robots the gears are glued onto the gearbox shafts with a press fit and the retaining compound. The retaining compound part number is 638. I have my Loctite catalog right here and this is what it says about 638 "A maximum strength retaining compound for use where high dynamic force or cyclic loading is expected. Locks cylindrical assemblies up to .010" diameter clearance. Fixtures in 5 minutes. The shear strength steel/steel is 4500 lbs." The retaining compound is dark green and smells like vinegar. When you're done putting the gears onto the shafts it smells like you were dying Easter eggs!
The primer is #7471 "A solvent based primer that speeds the cure of all Loctite brand anaerobic adhesives and ensures proper cure on inactive metals.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 17-02-2006, 07:19
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Only a product that our team couldn't live without, JB Weld! It would work great depending on how much force this gear sees. If it isn't too hign then it will work. There isn't any product that will work as a glue under high torques. But JB Weld is the best thing for this situation. We've had to JB Weld our wheels together before and it held very well. Best thing is it sets quick
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 17-02-2006, 08:08
Gdeaver Gdeaver is offline
FRC #1640
The loctite product mentioned above will work. Metal must be very clean. If the surfaces are polished abraid them a little. Epoxy is less than desirable.
Unread 17-02-2006, 08:09
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
My vote is for the retaining compound, unless you have the room and desire to build up a large fillet of JB Weld on both sides of the shaft. JB Weld is really not intended for this sort of usage; it's better for static applications.
Unread 19-02-2006, 13:51
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
i've used the retaining compound before (green) and it works well. I only used it to secure a set of bearings, and it retained them very well.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 19-02-2006, 15:00
Dick Linn's Avatar
no team (Synergy)
I assume you mean the gear broke because the press fit was too tight. You could put the shaft in a drill and use emery paper to gradually reduce shaft diameter until the press fit is not so tight. We had to reduce the kit gearbox output shaft diameter by about .005 inches using this method. You can start with a file if you have to reduce it a lot. We happened to use some abrasive roll material.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 19-02-2006, 17:25
President, VEX Robotics, Inc.
Listen to Jay in the post above. Use Loctite 638 or 680. You must have an engineered gap, though. An engineered gap is a gap between the shaft and the hub diameter that you put there on purpose. Take your press fit and reduce it to 0.001" only in the middle. Put gaps (smaller than 3/8" diameter) on each end of the shaft where it contacts the gear. The press fit will pilot the gear and the gap with Lactate will bond it in place. This will work. Reference the Lactate design guides (online). They can help.
-Paul
Unread 19-02-2006, 18:06
We figured out a way to key the gear. But thanks for all the comments and suggestions.
Unread 15-01-2007, 03:57
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
I wanted to bump this thread up again to ask a few questions. First, we are trying to fasten a 20 tooth, 1/2" thick, 1.000 PD gear to the big minibike CIM for our transmission. However, the D-shaft eludes any easy way of attaching the gear securely on. Can the gear be fastened to the shaft just by the retaining compound, or is a press fit/retaining compound combination preferable? Any other ideas?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 15-01-2007, 05:40
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
-Paul
So - we could use milk as a retaining compound?
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
mounting of the small gear directly to the shaft of the drill Andrew Dahl Motors 0 19-01-2004 12:18
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
