Go to Post If I was making this I would want to not have to use anything smaller than a 3/16" end mill, but 1/8" would be acceptable. Anything smaller and I'd tell the designer to go play in traffic. - Cory [more]
Unread 19-02-2006, 13:54
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Re: Invalid Address
What version of the IFI Loader are you using?
Sean
Originally Posted by team 803
I brought up the IFI Loader and tried to load up our hex file, but a message came up that said:
Invalid Address: 0x0 (correct Range: 0x800-0x7fff)
How do I fix this
Unread 19-02-2006, 13:57
team 803 team 803 is offline
Wow! a whole week1/2 of experience
FTC #0803 (Hawks)
team 803 is an unknown quantity at this point
Re: Invalid Address
v-1-0-0
Unread 19-02-2006, 14:01
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
Uninstall 1.0.0 and install 1.1.0 (2 Feb 06)
http://www.ifirobotics.com/docs/ifi-loader-v1-1-0.zip
Post if it fixes your problem.
Sean
v-1-0-0
Unread 19-02-2006, 14:08
FTC #0803 (Hawks)
Re: Invalid Address
I still recieved an invalid address range error
Unread 19-02-2006, 14:12
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
Take a look at this thread:
http://www.chiefdelphi.com/forums/showthread.php?t=25662&highlight=Invalid+Address%3 A+0x0+%28correct+Range%3A+0x800-0x7fff%29
found this by searching for:
(search on the Orange bar above the ads)
(change the 18f8720.lkr with 18f8722.lkr - in the answer)
Sean
Unread 19-02-2006, 14:18
FTC #0803 (Hawks)
Re: Invalid Address
18f8722.lkr is the linker I have in it
Unread 19-02-2006, 14:23
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
Hmm, let's see. Maybe do a 'Clean' (Project, Clean in MPLab). Also, check to make sure the device in the Configure, Select Device is the 18F8722 processor.
Sean
Unread 19-02-2006, 14:26
FTC #0803 (Hawks)
Re: Invalid Address
Yes I have that device selected, now, when I am exporting the hex, do I need to edit anything on the window that pops up? Program Memory Areas?
Unread 19-02-2006, 14:37
FTC #0803 (Hawks)
Re: Invalid Address
under the program memory checked box it has Start:0 End:0x1fffe
"Vir prudens non contra ventum mingit"
"Machina improba! Vel mihi ede potum vel mihi redde nummos meos!"
Unread 19-02-2006, 14:38
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
I don't think you need to do the export. Just do a build (F10 or CTRL-F10) and then grab the .hex file that is created. I've never had to do export to get a .hex file that will load.
Sean
Unread 19-02-2006, 14:42
FTC #0803 (Hawks)
Re: Invalid Address
Well, when I clicked build all, it didn't do anything.
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
It sounds like a configuration problem. Has it worked in the past?
Sean
Unread 19-02-2006, 14:45
FTC #0803 (Hawks)
Re: Invalid Address
It built when I was over at Bosch, but it hasn't worked since I brought it here.
Unread 20-02-2006, 10:33
Re: Invalid Address
That's not normal. Are you sure you opened the project (.mcp file) using the Open... command of the Project menu, and not just the individual source text files using the File menu?
Unread 20-02-2006, 12:51
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Invalid Address
Could it be your output window is simply not visible. See if my post in this thread helps.
Mailing Address for Team 271 BobC General Forum 5 21-03-2005 20:35
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
Invalid Thread Specified Jay H 237 CD Forum Support 2 02-03-2004 21:01
Invalid Autodesk email address? NickZ 3D Animation and Competition 2 23-02-2004 01:35
E-mail address shows Pat Fairbank CD Forum Support 1 23-12-2003 18:46
