Go to Post "Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein - Edward Debler [more]
Unread 19-02-2006, 13:44
team 803 team 803 is offline
Wow! a whole week1/2 of experience
FTC #0803 (Hawks)
team 803 is an unknown quantity at this point
Invalid Address
I brought up the IFI Loader and tried to load up our hex file, but a message came up that said:
Invalid Address: 0x0 (correct Range: 0x800-0x7fff)
How do I fix this
Unread 19-02-2006, 13:54
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Re: Invalid Address
What version of the IFI Loader are you using?
Sean
How do I fix this
Unread 19-02-2006, 13:57
FTC #0803 (Hawks)
Re: Invalid Address
v-1-0-0
Unread 19-02-2006, 14:01
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
Uninstall 1.0.0 and install 1.1.0 (2 Feb 06)
http://www.ifirobotics.com/docs/ifi-loader-v1-1-0.zip
Post if it fixes your problem.
Sean
v-1-0-0
Unread 19-02-2006, 14:08
FTC #0803 (Hawks)
Re: Invalid Address
I still recieved an invalid address range error
Unread 19-02-2006, 14:12
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
Take a look at this thread:
http://www.chiefdelphi.com/forums/showthread.php?t=25662&highlight=Invalid+Address%3 A+0x0+%28correct+Range%3A+0x800-0x7fff%29
found this by searching for:
(search on the Orange bar above the ads)
(change the 18f8720.lkr with 18f8722.lkr - in the answer)
Sean
Unread 19-02-2006, 14:18
FTC #0803 (Hawks)
Re: Invalid Address
18f8722.lkr is the linker I have in it
Unread 19-02-2006, 14:23
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
Hmm, let's see. Maybe do a 'Clean' (Project, Clean in MPLab). Also, check to make sure the device in the Configure, Select Device is the 18F8722 processor.
Sean
Unread 19-02-2006, 14:26
FTC #0803 (Hawks)
Re: Invalid Address
Yes I have that device selected, now, when I am exporting the hex, do I need to edit anything on the window that pops up? Program Memory Areas?
Unread 19-02-2006, 14:37
FTC #0803 (Hawks)
Re: Invalid Address
under the program memory checked box it has Start:0 End:0x1fffe
"Vir prudens non contra ventum mingit"
"Machina improba! Vel mihi ede potum vel mihi redde nummos meos!"
Unread 19-02-2006, 14:38
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
I don't think you need to do the export. Just do a build (F10 or CTRL-F10) and then grab the .hex file that is created. I've never had to do export to get a .hex file that will load.
Sean
Unread 19-02-2006, 14:42
FTC #0803 (Hawks)
Re: Invalid Address
Well, when I clicked build all, it didn't do anything.
TimeOut's Avatar
AKA: Sean Kelly
Re: Invalid Address
It sounds like a configuration problem. Has it worked in the past?
Sean
Unread 19-02-2006, 14:45
FTC #0803 (Hawks)
Re: Invalid Address
It built when I was over at Bosch, but it hasn't worked since I brought it here.
Unread 19-02-2006, 15:09
FTC #0803 (Hawks)
Re: Invalid Address
So, I have the program all ready to go, but I can't download it to the robot.
Mailing Address for Team 271 BobC General Forum 5 21-03-2005 20:35
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
Invalid Thread Specified Jay H 237 CD Forum Support 2 02-03-2004 21:01
Invalid Autodesk email address? NickZ 3D Animation and Competition 2 23-02-2004 01:35
E-mail address shows Pat Fairbank CD Forum Support 1 23-12-2003 18:46
