Go to Post Success isn't from winning nationals but from improving as a person or as team. Putting the minds together in order to get the job done is success. - Melissa Nute [more]
Unread 19-02-2006, 13:38
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Distance calculations
We are looking for the complete code to calculate the distance from the camera to the light...
Thanks in advance.
Unread 19-02-2006, 14:28
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Re: Distance calculations
http://www.chiefdelphi.com/forums/sh...amera+distance
Specifically
The camera center to target center formula is similar:
camera to target angle = target pixel * (camera fov angle / camera pixels) - center pixel
Then combine:
bot to target angle = bot to camera angle + camera to target angle
This might also be helplful, but it is about how to calculate the angle to which one should fire.
http://www.chiefdelphi.com/forums/sh...e ra+distance
Unread 19-02-2006, 19:17
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Then once you have an accurate tilt angle from the camera to the target it is normal trig (tangent) to use that angle and the vertical height between the camera and the target center.
The article Windward quoted I do not believe has any example code with it. I certainly never went that far since our team isn't using the enhanced accuracy values.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 22-02-2006, 21:38
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
We had a nice Distance_Function() in our program using the tan function and everything, but we found it to not be necessary, since it correlates directly to the tilt_angle so we mapped out distances using the tilt angle as a primary source of measure, works the same, it's just much simpler.
www.sabrerobotics.com
get distance from cmucam ModMan24 Programming 14 29-10-2010 17:51
Sharp IR distance sensors Gdeaver Electrical 13 10-02-2007 20:36
Some ways to measure distance during autonomous shamu1001 Programming 2 06-02-2006 15:24
Long distance... Ashley Christine Chit-Chat 6 27-04-2005 15:11
Distance timing out bludstayne Programming 5 05-03-2004 13:47
