Go to Post I am surprised at the relative conservative capability you described on our 2006 machine. As for the 2007 machine, in anticipation of an aquatic game, we have completed a robot that "walks on water" and are well along with one that can "part the sea". - Bill Beatty [more]
Unread 13-02-2006, 21:55
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Chain Tensioners
Originally Posted by lukevanoort
Eventually I had to ditch the design because we needed four tensioners. (Can anybody guess what we're doing? Hint: not omni)
OO oo pick me Possibly Mechanum? We still have to try running it on the floor over a period of time with the tensioners to see how they do, which we will on Wednesday. We didn't really consider the chain sliding sideways, didn't have much of a problem when we had it propped up on the table. Oh well, we'll see.
Unread 13-02-2006, 23:46
in between teams
AKA: Luke Van Oort
I wish. Maybe next year...
Team 1219: 2009 - Mentor
Unread 14-02-2006, 11:23
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
We use elastomer tension rings from McMaster-Carr (p/n: 5896K1). They work great and are simple to install (just put it between the chain). See attached image...
Unread 15-02-2006, 16:50
Dick Linn's Avatar
no team (Synergy)
Those tensioning rings are slick. Too bad they cost so much! At that price, the special polymer must be made from unobtanium.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 16-02-2006, 20:22
King Bob's Avatar
King Bob King Bob is offline
AKA: Ben "Bob" Karas
FRC #0555 (Montclair Robotics)
King Bob is an unknown quantity at this point
Send a message via AIM to King Bob
We made a tensioner for our 05' bot. We just used a skateboard wheel on a piece of metal which was attatched to the frame and a spring keeping the tension. We just used scrap parts from our school so it was cheap and pretty easy to make. I'll try to get a picture up soon.
Unread 16-02-2006, 20:40
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
we are just using bolts to tension our chain but we want to use something on top of the bolts...
Unread 17-02-2006, 15:34
in between teams
AKA: Luke Van Oort
Be careful, metal on metal contact is not a good thing. Ideally you'd use idlers, but if you can't at least put a piece of PVC around the bolt.
Unread 17-02-2006, 19:36
occra 23.
AKA: ryo
None #1481
i dunno if thats allowed... its not fair you can generate electricity from friction...
and we cant use them because of clearance issues.
weve had success in th past with no active tensioners. we have slots in our wheel bearing pillows. and we just slide them to the perfect tension. then crank on the bolts.
Unread 19-02-2006, 15:15
Dick Linn's Avatar
no team (Synergy)
If our design permits, we either slide or place shims under the motor/gearbox assembly. This year, the initial tension worked out perfectly with no shims or half links or anything. How unsual is that!
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 25-02-2006, 19:39
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
I know what type of tensioner you are talking about. Google "Roll-On Tensioner". It's this rubber sprocket that tensions and dampens vibrations. We have neve used it, but ive heard that its good suff.
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
How To Make Chain With Inventor 10 vVigglEs Inventor 6 28-01-2006 21:34
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
