Go to Post Did you know that if a G7, G27, G28, and G20 occur in that order at the same time, then the referee will appear to be doing the "YMCA"? :) - Jack Jones [more]
Unread 19-02-2006, 14:54
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Question Wiring for the allegro gear sensor
Recently we hooked up our gear tooth sensor and found it wasn't working. After looking at all the documentation we realised that they draw on 12 volt. After looking at the board itself it shows a small 12 over the W terminal. Before I connect anything I wan't to confirm what pin should get 12 volts and whether both sets of pin hookups run on 12 volt or if only one.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 19-02-2006, 15:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Wiring for the allegro gear sensor
I have the gear tooth sensors wired up according to the silkscreening on the board, and they seem to be working fine. +12 on one white wire, +5 on the other red one.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-02-2006, 15:15
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
The W with the 12 over it (the white pwm wire) is connected to the Circuit Breaker with a 20amp fuse. You don't *have* to connect the black wire to a negative terminal on the Circuit Breaker becuase you are already grounded through the digital output (but we connected it anyways). The red wire on the pwm cable that connects to the 12 volt is unused. We just taped it to the side of the other wires.
Also, make sure your sensor can *actually* see the gear. We put the gear box on backwards and it could not see anything (took us a while to figure out why it didnt work). You should be able to peep into the hole on the side of the gear box and see the sensor looking at a gear inside of it.
I hope this helps.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 19-02-2006, 15:17
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Please see the following documents for help,
-Michael Dessingue
Unread 19-02-2006, 17:03
Thanks all it works fine now. My concern was I didn't want to run power to what is normally the signal wire. We were able to get both working and progamed in the end.
Gear Tooth Sensor FIRE Aaron_H Electrical 5 17-02-2006 12:29
Gear Sensor Ryan O Programming 3 14-02-2006 09:56
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
