Go to Post try to be a little less quick to hit the red rep and a little more informative and helpful. - JaneYoung [more]
Unread 19-02-2006, 15:50
team 803 team 803 is offline
Wow! a whole week1/2 of experience
FTC #0803 (Hawks)
team 803 is an unknown quantity at this point
Joystick Programming
In the file where it shows the joystick controls, I have tried different arrangements so that one joystick will control all of the wheels, but the program lines that it had devoted to this in the file does not work.
I need it so that when lean the joystick left the right wheels go forward while the left go back and Vice-versa, can anybody give me a code that will do this.
I have tried to make one myself, but they don't work.
"Vir prudens non contra ventum mingit"
"Machina improba! Vel mihi ede potum vel mihi redde nummos meos!"
Unread 19-02-2006, 15:55
FTC #0803 (Hawks)
Re: Joystick Programming
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
pwm05 = p1_x;
pwm06 = p2_x;
pwm07 = p3_x;
pwm08 = p4_x;
01 will be the right while 02 will be the left, how do I set that up so that one will reverse while the other goes forward (as described above)?
Unread 19-02-2006, 16:12
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
copied from innovation first's 2006 default programming
  pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
If you dont want to use 13,14,15,16 change 13,14 to 01 and 15,16 to 02 and
  //pwm01 = p1_y;
  //pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
That should map the joystick movement to one stick drive.
-Mike
Unread 19-02-2006, 16:17
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
If you are using the default code and want 1 joystick drive, make sure your right motors are in pwm13/pwm14 and that your left motors are in pwm15/pwm16.
Unread 21-02-2006, 07:54
FTC #0803 (Hawks)
One detail I forgot, the left motors are connected through one wire and the same with the right.
Unread 21-02-2006, 11:33
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
That's perfectly fine. You don't need to use both 13 and 14, or both 15 and 16. Just one or the other. 13 and 14 are exactly the same, as are 15 and 16.
void function(void)
  function();
Unread 21-02-2006, 11:49
FTC #0803 (Hawks)
We are using the second stick for the launcher, I am not quite sure how to set that up (two weeks experience with programming). We need it so that when the top button is pressed, the motor starts. (I think that would be aux)
pwm 04
Then when the stick is pressed forward it moves the other motor forward and when moved backwards it goes backwards.
pwm 05
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
single joystick programming Bill Bonsky OCCRA 2 04-10-2003 09:47
Programming the second joystick in PBASIC archiver 2001 2 24-06-2002 00:25
