Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
Unread 19-02-2006, 13:42
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Reading switches during Autonomous
We plan on setting the autonomous mode from the operator interface. My question is can the Operator Interface be queried (specfiically P3/4 Switch definitions) during the autonomous mode. Obviously, these switches would be set prior to the start of the match and would initialize to the state they are positioned during robot initialization.
Thanks!
D. Sean Kelly
Team #499 - Programming Mentor
Unread 19-02-2006, 14:03
Re: Reading switches during Autonomous
Sort of.
when the robot is disabled it still reads all the inputs (RC and OI), only the outputs are blocked.
When Auton mode begins the robot will not be able to read any inputs from the OI, but if you write your code to remember what the switch settings were while the robot was disabled, you can use those values during auton mode.
Unread 19-02-2006, 14:04
TimeOut's Avatar
AKA: Sean Kelly
Thanks! More last minute testing I guess
Sean
Originally Posted by KenWittlief
Sort of.
Unread 19-02-2006, 16:23
CarpeDiem CarpeDiem is offline
FRC #0135
CarpeDiem is an unknown quantity at this point
If i put switches on straight to the RC i need ot know is a digital only 0 or 1 with a switch. what i am trying to say if i have a switch in digital 1 and two would i say
if (rc_dig_in01){
rc_dig_in02=0;
or what would i use to tell it i dont want digital 2 on.
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
