Go to Post If I had come up with a chokehold strategy, I wouldn't talk about it on Chief Delphi. - Tom Bottiglieri [more]
Unread 18-02-2006, 17:49
kokodabear's Avatar
kokodabear kokodabear is offline
HELP!
AKA: Brady
#0686 (Bovine Intervention)
kokodabear is an unknown quantity at this point
Send a message via AIM to kokodabear
Camera Shorts (and starts smoking)
We had our camera set up on our test robot and it worked flawlessly. We got our robot to turn towards the target and everything. We hooked it up to our competition robot and it initially worked the same.
One day the power PWM cable decided to melt and it smoked. It was plugged in correctly, and it worked when we replaced the PWM cable. Then today it started smoking again. I am pretty sure that it is shorting.
Anyone else have this problem? Any ideas for the cause?
Unread 18-02-2006, 19:27
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Camera Shorts (and starts smoking)
Proper amount of spacers behind the camera?
Unread 18-02-2006, 19:35
kokodabear's Avatar
HELP!
AKA: Brady
We thought about that issue after the first short, so we covered the whole back with electrical tape.
Is that a bad idea?
Unread 19-02-2006, 10:00
Originally Posted by kokodabear
bad idea?
Electrical tape does nothing against the sharp points of solder on the back of the camera board.
It must be insulated by an air gap you can see through.
Unread 19-02-2006, 11:29
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
I found that foam tape works well for insulating. We had an issue with our GTS shorting out with the Gear Box becuase of the sharp solder points. We first ground them down, covered them with electrical tape, then a bit of foam tape insace anything wants to poke through.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 19-02-2006, 16:32
kokodabear's Avatar
HELP!
AKA: Brady
If our camera no longer works (I mean it has only shorted twice ) can we replace it with the kit camera from last year? They appear to be the same model.
Thanks for all your help.
Unread 19-02-2006, 17:16
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
yeah they are interchangeable. Before you do though find the problem.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 20-02-2006, 20:50
kokodabear's Avatar
HELP!
AKA: Brady
some good ol' styrofoam did the trick. no more exploding camera! thanks guys.
