Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
  #31   Spotlight this post!
Unread 19-02-2006, 01:19
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Got Weight?
Today we finally got a chance to weigh our robot, and much to our suprise we came in at an alarming 160 lbs. Didn't see that coming.
We weighed it with the battery, though, so we are only about 25 lbs overweight. 8 hours of drilling/punching/crying, we got rid of an excess 15 pounds or so, but we still have a ways to go. We may only have 2 motors for our drivetrain in the end...
Oh well, lesson learned.
  #32   Spotlight this post!
Unread 19-02-2006, 01:30
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: Got Weight?
Originally Posted by JVN
You could replace heavy steel sprockets with lightweight aluminum ones.
That might save a few pounds.
Or even nylon sprockets. We've been using them for our drive wheels the past two years. Just be careful about using them in very high torque areas.
  #33   Spotlight this post!
Unread 19-02-2006, 16:18
Richsgt Richsgt is offline
AKA: Rich
FRC #0836 (Bobcat Robotics)
Richsgt is a jewel in the roughRichsgt is a jewel in the roughRichsgt is a jewel in the rough
Send a message via AIM to Richsgt
Re: Got Weight?
One little piece of advice, look at the game footage from recent and try to prioritize what is most important, because if you design the robot and plan for 4 drive motors then only have 2, you might have problems as well as the system itself so look carefully before taking out portions of systems.
Otherwise, drill away as the omni bit is your friend
  #34   Spotlight this post!
Unread 19-02-2006, 16:33
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
Re: Got Weight?
If you have a lot of lexan on your bot, you may want to invest in a hole saw bit. Example, we had a lot of lexan on our bot...we weighed in at a cool 128 lbs. After removing un needed metal and making our bot very holy, we are down to 89lbs (and fast) :-)
Just remember that structural support is very important. Often you can drill holes as needed, provided you know what you are drilling into.
Good luck!
  #35   Spotlight this post!
Unread 19-02-2006, 17:08
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
Re: Got Weight?
Last year we were about 20lbs overweight. Its supprizing how little material is really needed for structural stability. We removed 8lbs of aluminum from our arm- boy that was a long night. We also replaced about 5lbs of steel bolts with plastic ones. They really dont come close to reaching their yeild strength.
This year, thanks to keeping track of the weight as we built, were at a cool 90lbs!
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
  #36   Spotlight this post!
Unread 19-02-2006, 17:17
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Wink Re: Got Weight?
thanks but we just had to get lighter materials and now were under
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
  #37   Spotlight this post!
Unread 19-02-2006, 18:10
Dick Linn's Avatar
no team (Synergy)
Re: Got Weight?
If you are using PVC pipe anywhere, try using ABS instead. We had to replace our PVC pipe rollers with ABS. If we could have found the very thin (say 1/16") ABS drain or vent pipe, we would have used that. There is also electrical conduit that is a foamed core PVC which is quite a bit lighter.
Some of the electrical components and non-stress items can be held on with nylon fasteners.
Steel sprockets can be shaved down quite a bit if you have machining facilities. If not, ask a local community college that has machining courses.
If you are using the kit frame, there's ways you can cut out a lot where the frame rails and joining pieces overlap since it seems to be a bit overkill.
Depending on the nature of the joint, you may be able to use a smaller but stronger bolt. One year, we used 10-32 allen head cap screws to hold our entire frame together rather than 1/4 inch bolts. A good grade of 10-32 is about as strong as a crummy hardeware store 1/4 inch bolt made with soft steel. We prefer grade 5 and grade 8 fasteners. You might be able to have some joints in aluminum welded to reduce the weight of overlapping sections and bolts. You may be able to grind a bit off the tops of bolt heads.
If you are using a converor belt of some sort, perhaps you can punch holes in it. We used some 2 ft wide rubberized cloth conveyor belt, similar to what tou'd see at a grocery checkout but fairly thin. Tough stuff, but very heavy. We sharpened up the end of a piece of small diameter car exhaust tubing and pounded out about 250 holes, cookie-cutter style. Had to use soapy water to get it to cut cleanly, and sharpened often.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #38   Spotlight this post!
Unread 19-02-2006, 18:35
Steve S.'s Avatar
Steve S. Steve S. is offline
2008 FIRST Volunteer =D
FRC #1591 (Greece Gladiators)
Team Role: Webmaster
Steve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the rough
Send a message via AIM to Steve S. Send a message via MSN to Steve S. Send a message via Yahoo to Steve S.
Yeah, a little too much weight
Swiss Cheesing it.....overtime
  #39   Spotlight this post!
Unread 19-02-2006, 19:35
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Re: Got Weight?
We weighed in five lbs over weight, but since we have a lexan tube surrounding our spiral, we will most likely be making it more air than actual material.
Hehehe drills.
For the random comment, anybody see the Strongbad where he drills Strongsads bellybutton? Its under an episode about how the stick got its place/name/something.
VEX Robotics Blog
  #40   Spotlight this post!
Unread 19-02-2006, 20:05
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Got Weight?
Originally Posted by Tom Bottiglieri
Take the white space out of your program.
... and the comments. Nothing worse than weighty comments!
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
  #41   Spotlight this post!
Unread 19-02-2006, 23:37
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Got Weight?
Since you're pimpin your products again John, in case EO didn't call can you make sure ours get shipped tommorrow?
Pete
Thank-you 294 & 67
www.bobcatrobotics.org
  #42   Spotlight this post!
Unread 19-02-2006, 23:58
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Got Weight?
We are under weight, but we have a very important component to add yet...
I just went through with the mill and took a couple of mounting blocks that were 17 ounces each down to about 5.03 ounces each
Looks like I have a lot more to do...
  #43   Spotlight this post!
Unread 21-02-2006, 21:21
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
Re: Got Weight?
Ours is like 7 pounds underweight, which is good. We decided to use those spare pounds to balance out the robot and help it come off the ramp without tipping (which has happened to us twice).
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
  #44   Spotlight this post!
Unread 21-02-2006, 21:50
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Got Weight?
Hmm... I can't imagine those being strong.
All I can think about is them getting torn to shreds in the middle of a pushing match.
  #45   Spotlight this post!
Unread 21-02-2006, 22:20
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Got Weight?
Our team was able to lose 10lbs off the robot in 1 day.. BEAT THAT JENNY CRAGE!
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
