Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 19-02-2006, 18:55
wvenhau wvenhau is offline
wvenhau is an unknown quantity at this point
Using Send Frame Command
Hi,
I recently purchased the CMUcam2+ and I'm trying to send a frame to a PIC to do further image processing. I'm using the SF command to send it and when I do I'm receiving a whole bunch of garbage (ASCII characters). This doesn't surprise me because that's what the manual says it suppose to do. However what I'd like is to have the RGB data (i.e. a array of integers).
Can I have the CMUcam2+ send the PIC this information?
Or, do I need the PIC to decode the the ASCII characters and produce my array of ints? If so, I haven't got the foggiest idea of how to do so.
Any help will be greatly appreciated.
Thanks,
Bill
Unread 20-03-2006, 12:32
Don Reid Don Reid is offline
Don Reid will become famous soon enough
Re: Using Send Frame Command
The CMUCam sends RGB data as binary values, a series of bytes.
Look at the documentation for "F packets". However don't look too closely.
I have found several versions that are different, and none match what I see
the camera doing. (To be sure of what your camera is doing, dump the
first few bytes out with a printf, or dump it all to a file and use a hex viewer.)
This is what I found to work, the camera outputs:
- a byte of 0x01
- a byte with the x size (number of pixels in a row)
- a byte with the y size (number of rows)
- bytes of pixels data, 3 bytes per pixel,
--- a byte with the red value of this pixel
--- a byte with the green value of this pixel
--- a byte with the blue value of this pixel
The number of these bytes is xsize * ysize * 3
- a byte of 0x02
- a byte of 0x03
If you count bytes, you can ignore these last two, but they can help you
tell when you have dropped data. None of the pixel data bytes will be less
the 16. The older your computer, the more likely that the serial link will be unable to keep up at high baud rates, try running at a slower baud rate.
Don Reid
Creating a digital picture frame Billfred Chit-Chat 2 21-01-2006 09:52
Won't grab frame in Labview Robert Dores Programming 2 14-01-2006 04:13
using eclipse dasRatsel Programming 82 02-01-2006 13:20
Software Development System Installation Mike Betts Programming 26 25-07-2005 10:48
programming codewords black mage Programming 9 23-02-2005 21:21
