Go to Post do the math, then use the math to go for total overkill. - pfreivald [more]
Unread 19-02-2006, 18:44
jlewellen jlewellen is offline
AKA: Jacob Lewellen
#0859 (Boing)
jlewellen is an unknown quantity at this point
Setting Trim on Old 3D joystick
My team finally completed the robot enough so that I (as programmer) could work on it a couple days ago. I'm trying to use a 3D joystick to control the drive for omniwheels. The problem is the joystick's trim is way off. It doesn't appear to have anything to set the trim physically. It's a Microsoft Sidewinder 3D Pro. Does anyone have any ideas how I can set the trim?
Unread 19-02-2006, 19:01
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Setting Trim on Old 3D joystick
The MS Sidewinder 3D pro uses optical sensors to sense movement. Despite having a db15 connection, its not an analog joystick. There are no trims to set, and unfortunately, it won't work.
Sorry.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 19-02-2006, 21:03
Adrien's Avatar
Adrien Adrien is offline
FRC #1414 (IHOT)
Adrien is an unknown quantity at this point
Send a message via MSN to Adrien
Well, there may be no mechanical manifestations of ways to trim it, but it can always be adjusted in the program!
Just set it to its neutral state, and tell the programmer to work around it (I'm sure the programmer will be overjoyed ). It's better than nothing I suppose.
Free programming help Cuog Programming 24 24-01-2006 16:43
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
