Go to Post Know that CD is a safe environment to learn to talk with a foot in your mouth. - Andrew Schreiber [more]
Unread 19-02-2006, 23:15
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
pic: team 1029
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 19-02-2006, 23:30
bjimster1's Avatar
AKA: Jimmy Bourne
Re: pic: team 1029
GENERAL
2-speed transmission (mechanical shift)
4x6 wheel drive
Weight: 120lbs
Measurements: 27 wide x 37¾ long x 28¼ high
Ball capacity: 18 balls
Center of gravity low and centered with respect to the robot
TORQUE:
LOW GEAR/STALL: 137.3 ft-lbs
LOW GEAR/MAX POWER: 68.67 ft-lbs
HIGH GEAR/STALL: 54.92 ft-lbs
HIGH GEAR/MAX POWER: 27.47 ft-lbs
HORSEPOWER:
LOW GEAR @ 2655 RPM: 34.7 hp
HIGH GEAR @ 2655 RPM: 13.88 hp
SPEED:
LOW GEAR @ 5000 RPM: 4.54 ft/sec
HIGH GEAR @ 5000 RPM: 11.3 ft/sec
SENSORS:
Photoelectric sensor tells RC when robot is close enough to wall to release balls. In autonomous mode, robot knows to release balls, during human operation, lights illuminate on the Operator Interface to indicate to the operator that the robot is close enough to release the balls into the goal.
The Allen Bradley photoelectric sensors detect when a ball crosses its path, this sends a signal to the RC which then activates the rollers of the ball pick up system to spin. This allows for optimum battery conservation and effective ball retrieval.
CMU '11
Unread 19-02-2006, 23:55
Keo-san's Avatar
Keo-san Keo-san is offline
AKA: Victor Marmol
FRC #1029 (WolvCats)
Team Role: Driver
Keo-san is an unknown quantity at this point
Re: pic: team 1029
Hey, Funny fact. I coded your bot!
Team 1029
www.wolvcatrobotics.com
CMU '11
Unread 20-02-2006, 00:26
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Re: pic: team 1029
To be completely honest, you guys are insane. I do mean that in the best way possible, but you practically broke our goal!
Here's a screen-cap:
Video (ownage around 50 seconds): http://funtimenetwork.com/scrimmage.wmv
Can't wait to see the carnage you guys dish out at UCF!
Unread 20-02-2006, 14:04
bjimster1's Avatar
AKA: Jimmy Bourne
Re: pic: team 1029
how about what happened with swamp's side of the field, we almost killed you guys. sorry about that. it's hard to control the beast. lol
we definitely look forward to seeing you guys at UCF.
CMU '11
Unread 20-02-2006, 14:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: team 1029
Originally Posted by bjimster1
HORSEPOWER:
Try again. That's enough horsepower to get a one ton car up to freeway speeds. I'm thinking your decimal point needs to shift one place to the left. But why would your horsepower change between high and low gear?
And for your "max power" numbers, since when is power measured in ft-lbs. Where is the unit of time?
Unread 20-02-2006, 15:19
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: pic: team 1029
i suspect they meant torque at max power (not max power itself).
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 20-02-2006, 16:14
Keo-san's Avatar
AKA: Victor Marmol
Team Role: Driver
Re: pic: team 1029
yeah we do mean torque at max power
Team 1029
CMU '11
Unread 20-02-2006, 16:31
Re: pic: team 1029
Okay, my mistake for misreading your table. But I still don't understand how even cumulatively all the robots in one match could put out 34 horsepower.
Unread 20-02-2006, 19:07
bjimster1's Avatar
AKA: Jimmy Bourne
Re: pic: team 1029
hp = torque * RPM / 5252
hp = 68.37ft-lbs * 2655 RPM / 5252 = 34.56
well horsepower is torque times RPM divided by a constant. there is a difference in torque at the same RPM depending on what speed it is in. motors and engines can have varying horsepowers; it depends on both the RPM and the torque at that RPM.
CMU '11
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Need Help and Suggestions - Creating a TEAM Freddy Schurr Team Organization 7 30-03-2005 22:00
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
