Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 20-02-2006, 04:06
jrmarenda jrmarenda is offline
AKA: Jason Marenda
FRC #1887 (Russet Robotix)
jrmarenda will become famous soon enough
Re: Control Problems
This shoudl fix your problem:
pwm13 = pwm14 = Limit_Mix(2000 - p1_y - p1_x + 381);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
I had the same problem, and figured out the answer by simply setting up a table with actual and desired values using the dashboard viewer. I have tried this on our robot and it works. Le t me know if it doesn't work out for you.
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Electronic Speed Control Problems DustinB_3 Electrical 9 09-11-2005 23:42
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 22-08-2005 12:53
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 12-06-2005 01:51
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
