Go to Post "The purpose of computation is insight, not numbers." - Tom Ore [more]
Unread 20-02-2006, 05:21
Ben Englert Ben Englert is offline
FRC #1072
Ben Englert has a spectacular aura aboutBen Englert has a spectacular aura aboutBen Englert has a spectacular aura about
Remote programming box
Hey guys,
I designed this around the Sparkfun BlueSMIRF bluetooth serial module. Basically it is a diagnostics box that allows us to get printf data back during testing.
The clever part is using the ground in one of the relay outputs on the RC to map an OI button to "program state" - remembering that this relay output will shut off as soon as the RC actually enters the state. All of this travels through a bridged pin on the connector, so the robot can only put itself in program state with this (non-competition-legal) wireless programming box connected.
After looking at that, is there anything else I should add? The BlueSMiRF does not have any opportunities for attaching a diagnostics LED of any kind, but I thought maybe I could put in a power LED on the +5 for completeness' sake.
But I still have some space on my DB15, so feel free to make suggestions.
Unread 20-02-2006, 13:44
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Re: Remote programming box
How does the wireless program_state swith work? I found the prog/ground pins on the 2004/2005 (forgot which) FRC RC. But how does the wireless connection start program_state
Unread 21-02-2006, 05:04
FRC #1072
You would use a digital pin on the RC and code it to turn on at some kind of joystick button press... basically it would be the RC putting itself into program state
Unread 23-02-2006, 17:55
Windward's Avatar
FRC #1452
Once I've created the bluetooth dongle, how do I interface with the actual CPU. What would I need to do to IFI loader or would I have to use something like Putty?
Unread 23-02-2006, 22:56
Umm Errr...
Nice work!
How well does this work? What kind of range do you get? Any data quality problems. I have always had it in the back of my head to get a remote rs232 link.
I did a similar thing bridging a digital IO pin to the program pin of the programming connector after i got tired of pressing the program button.
1139 Alumni
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Philadelphia Region - 2005 Remote Kickoff Joe Troy General Forum 2 01-12-2004 15:19
Qotw [11-17-02]: Manchester or remote kickoff... Ken Leung Rumor Mill 19 09-01-2004 16:18
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
