Go to Post My favorite question of all time asked by "outsiders": How much does/did that thing cost? How can you put a price on the hard-work and dedication it took to build these machines? - KyleGilbert45 [more]
Unread 05-02-2006, 12:14
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
robot controller 2005 2004
To upload this years default code or custom code to the 2004 or 2005 controller it seems like you should be able to just select the right Pic18f8520 for the compiler and thats that. I don't understand why you would do instructions 2 and 3. The needed files seem to already be included in the default set of files???
the following instructions came in the file called Using_last_years_frc which is a part of the default files.
To compile this project to work with your 2005 FRC (18F8520) system do the following:
1. Select the correct device from the MPLAB IDE.
Configure->Select Device->PIC18F8520
2. Replace the library file with the appropriate one.
Remove the FRC_Library.lib file and replace it with FRC_Library_8520.lib
or
Remove the FRC_alltimers.lib file and replace it with FRC_alltimers_8520.lib
3. Remove the 18f8722.lkr file and replace it with the 18f8520.lkr file
4. Rebuild your project and download the HEX file to your controller.
Can anyone shed some light on this?
Unread 05-02-2006, 13:27
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Re: robot controller 2005 2004
The library files are already compiled. So, switching the device in the MPLAB IDE will not do anything to recompile the libraries for the appropriate device. It will only compile your own code for the appropriate device. You have to tell it manually which library is appropriate. Hope that answers your question.
/* Daniel */
Unread 06-02-2006, 08:22
#0634 (Robowolves)
Thanks. it worked
The missing instructions (for those who are not MPLab proficient);
From the view of all files from MPLAB delete or remove the two files per insturction. Right Click on the library files heading and add files. Here you can select the FRC_library_8520 file. Then right click linker scripts and add the 18f8520.lkr file. If you selected the pic18f8520 device all will now compile correctly.
Unread 19-02-2006, 18:54
7wizted_rea1ity's Avatar
7wizted_rea1ity 7wizted_rea1ity is offline
AKA: 12053
FRC #0812 (Midnight Mechanics)
7wizted_rea1ity is on a distinguished road
Send a message via AIM to 7wizted_rea1ity Send a message via MSN to 7wizted_rea1ity Send a message via Yahoo to 7wizted_rea1ity
We tried using the 2005 controller for this year's code, following all the instructions in that one file (the same that was posted here before), but we got this error:
Error - section '.code_terminal.o' can not fit the section. Section '.code_terminal.o' length=0x00000202
o.0; What's that mean? The file's too big?
({}|\|(+|2(|7< 1|= `/()L| (ci|V |`(>/-\|) +|-|15
The truth is only as true as you believe it to be.
L|<>|_|'12|= 0|\/3 ()t` -|-|-|F |=3VV <i|3|_l=
Unread 19-02-2006, 19:41
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
I got that too. Can someone shed some light on this?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 20-02-2006, 09:43
The code's too large to fit within the smaller memory of the older robot controllers.
Check the size of the code in MPLAB using View -> Memory Gauge.
Caution: The value for program size is expressed in 2-byte integers and so must be doubled to get the number of bytes. The older controllers are limited to around 29K bytes while the new one has 126K or so available.
New Model Posted - 2004 Robot Controller Ed Sparks Inventor 10 07-01-2006 23:12
Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005 coastertux Inventor 4 14-06-2005 09:27
Possible Robot controller problems mpalermo81 Technical Discussion 1 24-02-2004 22:43
Robot Controller Flips Out Eko Programming 6 22-02-2004 22:53
BLOWN COMPONENT! In need of 2004 Robot controller to borrow for 2 days Michael Luedtke Electrical 9 22-02-2004 22:15
