Go to Post Well, are comedy and sarcasm COTS items? - Karibou [more]
Unread 20-02-2006, 08:24
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Dewalt Shifting Questions
A question for the teams who have successfully shifted the Dewalt XRP's.
Does it make a difference how you control your servos to shift? We are presently running both servos off a single PWM Y-cable, so that we only need to use one variable in the code. The alternative is to run two different PWM cables and use a second variable in the code. This isn't a difficult thing to implement, it's just a pain to switch it over at the moment.
Our concern is this... Since the servos are powered through the PWM cable, and we're presently splitting that with a Y, are the servos only receiving 1/2 of the power they require?
Thanks for all the help.
BEN
Unread 20-02-2006, 10:32
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
Re: Dewalt Shifting Questions
BEN
We are using the Y-cables to shift both servos at the same time. Actually, we are using two Y-cables to shift 4 servos at the same time (two sets of CIMs and DeWalts on each side.) It works fine.
Unread 20-02-2006, 12:08
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
if you are having trouble shifting the dewalts using the set-up described in the whitepaper, it may be because of the indexing clip; there is a small metal clip that serves as a spring that helps keep the dewalt in gear; unfortunately, it also makes it hard to shift using the servo. if this is removed, the servos shouldn't have any problem.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 20-02-2006, 13:40
Bengineer
Problem solved. It was a combination of a low backup battery (which powers the servos) and one of the dewalts with a sticky shifter. We replaced one entire side and it works just fine.
Thanks for the help with the Y-cable. And yes, we have already removed all the detent clips.
BEN
How To Ask Questions the Smart Way Brandon Martus General Forum 8 27-03-2013 15:52
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
