Go to Post Do give credit to the mentors, because they make you who you are. - Arefin Bari [more]
Unread 20-02-2006, 13:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: repurposing servos
Do you have some other PWMs or speed controllers that are working? You could try swapping the servo to a PWM you know is working and swapping the speed controller to pwm09. If the servo doesn't work, then it's a bad servo or wire. If the speed controller doesn't work, then it's something in your code.
Are Servos Motors? John Gutmann Motors 1 30-01-2006 18:41
CMUCam Servos not Responding on Robot krigby Programming 7 20-01-2006 23:19
Servos not getting right voltage sheyna Programming 2 17-01-2006 21:57
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
Hooking up 2 Servos kutty18 Programming 7 04-02-2005 09:26
