Go to Post The trick is to train the rest of the team to blame electrical instead. - Al3+ [more]
Unread 18-02-2006, 15:16
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
pic: Team 61 robot
Building FIRST robots since 1995
BVT Robotics
Unread 18-02-2006, 15:24
FRC #0061
Rookie Year: 1995
Re: pic: Team 61 robot
This is just before we shipped the robot. We can hit 10 from 10 from the first spot 9 to 10 for 10 from the second spot and 8 for 10 in the third spot which is the furthest away from the target. All in auto mode. once we get to the FL. regional we should be able to shoot better. it is just in the timing of feeding the balls.
This robot has 2 speed thanks to Andy Marks system.
We index the balls by air pistons. we took a video of the shooting before we ran out of disk space it should be up soon.
BVT Robotics
Unread 18-02-2006, 15:37
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
What material did you use to cover your bumpers. And where did you find it? Also any idea on your battery life running 4 small cims, 2 mini-bikes, and a compressor?
Great job on your autonomous, it an impressive feat to be that effective from that far out. You may want to try leaving more time inbetween each shot and maybe you'll increase its effectiveness from greater distances.
Unread 18-02-2006, 15:43
FRC #0061
Rookie Year: 1995
This is what we are working on. the wheel spins up very fast and keep its speed. that is why we use 2 big CIM motors.
the bumber stuff is the same stuff FIRST told us to get.
No compressor. we do not need it. we use the tanks.
BVT Robotics
Unread 18-02-2006, 15:44
that is a sweet looking machine!
Unread 18-02-2006, 17:01
Sgraff_SRHS06's Avatar
Sgraff_SRHS06 Sgraff_SRHS06 is offline
Kappa != 1/(4Pi-Epsilon-Naut)
AKA: Steve Graff
FRC #1111 (The Power Hawks)
Sgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the rough
Send a message via AIM to Sgraff_SRHS06 Send a message via Yahoo to Sgraff_SRHS06
Ditto! Well done, guys!
POWERHAWKS FORUM
2006 Chesapeake Regional Semifinalists (Thank you 614 and 339!)
UM Class of 2010!!
Unread 18-02-2006, 18:33
Billfred's Avatar
Billfred Billfred is online now
Agreed.
Out of curiosity, how hard is it to load?
Unread 18-02-2006, 19:01
FRC #0061
Rookie Year: 1995
very easy to load it
BVT Robotics
Unread 18-02-2006, 20:18
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
How does it get balls that aren't pre-loaded?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 18-02-2006, 20:51
FRC #0061
Rookie Year: 1995
why do we need balls after the auto mode
We play defence. just read what happen in CT. they played today. Defence will play a big part of this game
we shot in auto then hit.
BVT Robotics
Unread 19-02-2006, 07:59
FRC #0061
Rookie Year: 1995
Stats are:
Weight robot: 119.4 lbs
Bumpers: 14 lbs total
battery: 13 lbs
Total 146.4 lbs this gives the robot a lot of traction
CG is around 8" off the ground
Shoots in auto mode and shoots all the balls in 7.4 seconds
BVT Robotics
Unread 20-02-2006, 14:01
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
the two mini-bikes are only on for auto-mode unless we have a problem then they will only be on for another 10seconds. We have no compressor just a tank for the shifting. And the 4 CIMS, we run four drive motors every year and we never have had a problem why doing a lot of other stuff too.
Keep It Simple - Team 61's Motto
Any Thing on out Robot Can be Fixed in 5 Mins!
2005 Motorola Quality Award
2004 Battle Cry 5 @ WPI Eighth Finalists...4th Seed! 6-3 Record! Thx 237 & 830!
2004 Mayhem on the Merrimack Champions! 4th Seed! 9-2 Record! Thx 562 & 1289!
2004 Mayhem on the Merrimack Fastest Robot Award!
2004 Beantown Blitz Champions! 4th Seed! 11-1 Record! Thx 571 & 1100!
2004 National Semi Finalists
2004 Florida Regional Judges Award
2004 Florida Regional Champions! Thx 945 & 386!
Unread 17-11-2006, 14:14
Billfred's Avatar
Yeah, yeah, I know, ridiculous thread revival.
I was going through CD-Media looking for some ideas on drive systems, and I punched in frc61. I noticed along with the other pictures some earlier CAD drawings from this season (link). Was there anything in particular that triggered the switch in feeder designs?
Unread 21-11-2006, 06:41
FRC #0061
Rookie Year: 1995
Sorry about the late reply. Yes we had to switch from this design to the tube design due to the balls where getting stuck in the basket
BVT Robotics
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
