Go to Post One wouldn't want to keep the red herring in hand, that gets kind of stinky. - GaryVoshol [more]
Unread 20-02-2006, 17:59
Re: the firefly effect
on sailboats the sails and rigging are held up by shackles. Little U shaped fastners with a bolt that closes one end.
One of the tricks sailers play on noobs in their first race: at the start of the race you toss an open shackle onto the deck of the boat next to you.
The skipper thinks it fell off his mast or rigging, and stops to figure out where it came from. If you really lost a shackle from your rigging then either your sails, or you mast would come down.
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Hall Effect Sensor Transmission Placement robotoby35138 Electrical 1 06-02-2006 18:43
Hall effect sensor Filtering magical hands Programming 5 13-02-2005 11:23
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
