Go to Post We must remember: if you're reading this comment right now you already "get it." - akeisic [more]
Unread 20-02-2006, 21:29
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Controller problem, asap..
Our controller pwm outputs are probably not working.
Any advice?
5 Hours left for shipment...
Unread 20-02-2006, 22:03
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
Re: Controller problem, asap..
check your wires going into the victor....they can come loose. If that doesnt work, make sure they are pluged up the correct way
Team 302
Unread 20-02-2006, 22:21
1 CABLE BURNED OUT THANKS CYA!
Mini-Me robot arm controller Andrew Schuetze Control System 7 19-10-2005 11:07
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Victor controller problem llambele Technical Discussion 3 14-11-2001 23:00
