Re: Food for thought
one last thought: if the idea of sending parts out to be fabricated bothers you, go back and look at all the stuff that came in the kit of parts. The control system, the motors, the pneumatics, the compressor, the wires, the battery....
Imagine if you REALLY had to build everything from scratch! It would be impossible. |
ohk i know you said look for other threads but i have one last point. look at the new pic from team 1501 now not to take a shot at their team but honestly they must have a pretty high tech shop to build that by themselves. just to prove my point because most responses said that they build their own robot so i was just curious about 1501. Although as other replies have said there is no "right" way so watever works for your team i was just throwing the idea out there
4th year team here, 2nd year on it for me, and we've always had a student designed/built robot. We've had mentors machine complex parts for us and some other random stuff, but we do end up doing most of the machining and other stuff.
Actually.... All you need you need is: 1. A 1:1 plot of the part you are making, like a sidewall 2. Cut out your 1:1 plot. 3: Glue it on a piece of wood. 4. Cut out your peice of wood, this is called a FORMER block 5. Take your piece of wood to your alumium sheet. 6. Use a 1/2" circle with a hole in it to trace around your wood to make a 1/2 halo around the FORMER block. 7. Cut out your alumium piece with TIN SNIPS. 8. Use your former block to pound the edges together. 9. Klecko the thing together, when your happy, RIVET it. Seriously....that is IT...no CNC mill or LASER cutting required. It's VERY SIMPLE to make a robot like this... I am electrical, and I saw the kids make it they catch on fast. |
Lightning Robotics has been both a Mentor Driven team and a Student Driven team.
Back in 2000 and 2001 (as 465) a lot of the robot work was done by mentors. In 2002 with a new sponsor we switched to a Student Driven team and have been that way ever since. Last year we were worried about losing our machining capabilities, both access to the shop and mentors who had access to it, so we created our Hacksaw & Drill philosophy. We used this last year, designing the robot so that it could be using only simple hand tools. It worked extremely well. We used it again this year with one difference, we did lose easy access to our sponsors machine shop. The Hacksaw & Drill philosophy also allows more student involvement, a hacksaw requires much less training time than a band saw, and is safer to use. As a result our robots are almost 100% student built. Now this is how our team operates, I know other teams operate differently and thats fine. As for Student vs. Mentor built a lot of that can depend on the resources available to each team. It's common knowledge that some teams have better funding, or lots of mentors, or facilities better suited to build and test a robot. If they have them they should use them. Each team has its own way of carrying out the vision of FIRST. |
We used to build the frame to our robot then send it off to get welded. DuPont's safety standards don't allow welding in our workshop.
In 2004, we started using Bosch Tubing to build our frame. We still got it welded, but you can't weld that stuff well. The welding was really unnecessary anyway, and we haven't welded any frames since. Bosch Tubing is sturdy stuff and we don't have to wait for the welders anymore. ![]() |
#7
Our robot this year was 95% built by us. The other 5% were the trannies. They were manufactured and donated by one of our sponsors but assembled by the students. Last year we built our awesome robot (shameless plug ) in a church basement wood shop. That's right, a wood shop. Our high tech tools were a band saw, a table saw and a drill press. Along with the Clecos and Cleco pliers.This year we built it in a warehouse from space donated by another of our sponsors. They let us use their Bridgeport and lathe. We used the Bridgeport to mill our sprockets and to drill the 6 hole wheelchair wheel pattern. The lathe was used to create joining parts for the wheelchair wheels for our shooter. we could not use students for these processes as they were building the bot, the electrical board and doing the programming. As Chakorules stated all we do is form aluminum over a high tech wood form block. Last edited by Wayne Doenges : 28-02-2006 at 22:06. |
#8
CJBonez, I understand where you're coming from as I'm also from a team in which students do all of the building of the robot. I wouldn't have it any other way because I take great pride in our robot at the end of each season. It's a great accomplishment to be able to compete against robots that were sent away somewhere to be precision laser welded or something. I know that I'm not going to be in the pit polishing up the robot like some other teams. We're definitely going to be working out some of the kinks during practice. Just take pride in your robot and have fun. I've learned so much by building the robot with my own two hands rather than having the robot built by somebody else.
#9
7 years of Big MO and this is my 4th year on the team. Every year we concept the robot and make the parts out of wood then we have pars made that have to be precise made, and anything welded we mook up and hold together so it can be sent out to be welded. We in the past have ordered out frame thru 80/20 but for the this year and last year we have used extruded aluminum frame which was welded. 2 years ago we used a 1/4 inch thick aluminum plate (bad idea, but we won a regional). For the past 3 years we have used the same drive train and have only have 1 ort 2 chains break, and we have a total of 5 chains on each side.
When you say building a robot completely by the students i hope he is refering to assembly or parts and final construction. Because almost every robot has to have a precision part and if not something bad might happen. For instance, in this years game you might want to have a precise motor mount for your shooter if you h a direct drive. If your motor is not secure you might run into shafts breaking and wheels flying. Most parts on the robot do not needt to be precise but not every team is able to have a robot building spot such as GM or other corporate giant. These teams that do not need to have parts made outside of there shop, these teams might need outside fabrication. And if you think of what FIRST is trying to get us kids tolearn, it truly is just to make us further our knowledge by learning mechanical, electrical, programming skills. They are not saying we have to completely design, fabricate, and build our robot. But understand how things work and new innovative ideas on how to do things. ![]() |
#10
we design, build, and erm.... change our own robot. all student work. we do get input from the mentors because well hey, what else are they there for? but its all about the students.
#11
1568 is a second year team, and ive been on it for both years, as a driver and a college student now, it is still a student built team, with some adult help, the team is small and everything is done by everyone, there are no sub teams except for programming, being smallm helps us get the job done, the most widely used tool is the drill, and a tablesaw.
#12
Last year, Division by Zero worked with ThunderChickens and Dynamos for a large portion of the design. Many of the parts were built by them and then shipped to us, but that was mostly because they had the better facilities. Everything was also assembled and tested by the individual teams. In the end, if you looked at pictures of the robots side by side yes they were simular but they were also very unique.
We were a coalition. A team of teams, working together and exchanging ideas. Personally, I feel that is very much with in the spirit of FIRST. Much more so than if someone sat in their own little corner and said, no we're not talking to anyone. I think its really cool how teams help each other out in the pits, and we then extended it to build season. There's quite likely someone out here who knows more about the details then I do but figured I'd throw it out there. |
#13
| Buckeye Pre-Order Food | Kims Robot | Regional Competitions | 1 | 22-03-2005 15:42 |
| A New Recipe Thread...Because Food is Good | Eugenia Gabrielov | Chit-Chat | 2 | 11-01-2005 11:57 |
| Food at regionals? | Forsaken85 | Regional Competitions | 63 | 10-03-2004 16:17 |
| Aspartame | shyra1353 | Chit-Chat | 8 | 20-01-2004 22:41 |
| Thoughts on the food | Forsaken85 | Championship Event | 64 | 25-04-2003 15:53 |
