Go to Post Finally I wish everyone here on ChiefDelphi good luck and more importantly a fun build season. - mechanicalbrain [more]
Unread 20-02-2006, 23:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: repurposing servos
Originally Posted by KenWittlief
you are aware the servos run off the power from the little backup battery, yes?
also, make sure you dont have a line of code further down that sets the PWM9 port to 127. Teams often set the unused ports to 127, and then forget that line of code is in there!
I believe, if the servos are plugged into the main RC and not the camera, that they are run using the main battery. Whether or not an output is connected to a servo or motor is invisible to the controller, so it runs all outputs via the main. Servos are only powered by the backup battery if they are plugged into the camera.
http://www.mikesorrenti.com/
Are Servos Motors? John Gutmann Motors 1 30-01-2006 18:41
CMUCam Servos not Responding on Robot krigby Programming 7 20-01-2006 23:19
Servos not getting right voltage sheyna Programming 2 17-01-2006 21:57
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
Hooking up 2 Servos kutty18 Programming 7 04-02-2005 09:26
