Go to Post a robot can always be your girl. xcept for the fact you need to share - greencactus3 [more]
Unread 21-02-2006, 00:21
BranMan662's Avatar
BranMan662 BranMan662 is offline
Team 662 Alumni
AKA: Brandon Boyd
no team (Rocky Mountain Robotics)
BranMan662 is an unknown quantity at this point
pic: 662: Problem?
Robots With Altitude! ~ Team 662
DON'T
GET
ELIMINATED!!!
Unread 21-02-2006, 00:23
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: pic: 662: Problem?
Is that pneumatics I see? We almost went that route but couldnt due to weight (we're actually at like 119.2 lbs final weight). I would have liked pneumatics better, more precise then all the sensors we have for the door being up, being down, and the annoying issues with using cables.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 21-02-2006, 00:33
NK2007 NK2007 is offline
662's Manipulator VP
NK2007 is an unknown quantity at this point
Ya, we have 4 pneumatic cylinders... 2 are the rotary actuators, the other 2 are the small cylinders mounted to the bottom of the frame. The last two were a last minute addition (well actually the whole upper assembly was pretty last minute) but the rotary actuators wouldn't even budge the drawbridge. As far as weight, we are running right around 100 pounds- 98.something last time on the scale- looks like we are going for the steel plate again... lol
Unread 21-02-2006, 00:52
BranMan662's Avatar
Team 662 Alumni
AKA: Brandon Boyd
Oh yes, and I almost forgot about that, thanks for reminding me Neill. Our whole robot is about 20 pounds underweight. So much for lean, we're putting steel on that thing like no other
DON'T
GET
ELIMINATED!!!
Unread 21-02-2006, 01:15
KTorak's Avatar
Fire Rescue 47
AKA: Kyle Dersch
Team Role: Driver
Might I suggest using your weight to add higher guards on the sides of the door? It will help protect you from being pushed in, which results in a penalty. I know it was a big concern for us so we added 12inch sides on ours to prevent being easily pushed in.
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
