Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 21-02-2006, 00:41
comwiz7's Avatar
comwiz7 comwiz7 is offline
AKA: Joey
FRC #1323 (Madtown Robotics 1323)
comwiz7 will become famous soon enoughcomwiz7 will become famous soon enough
Send a message via MSN to comwiz7
Relay Programming Questions...
We need one button to change multiple relays several times, what would be a good way to go about doing this? Does anybody have any code that will do this?
Unread 21-02-2006, 01:13
MichaelGoldfarb MichaelGoldfarb is offline
AKA: Goldfarb
FRC #0312 (Heatwave)
MichaelGoldfarb is an unknown quantity at this point
Send a message via AIM to MichaelGoldfarb Send a message via MSN to MichaelGoldfarb
Re: Relay Programming Questions...
The best way to do this is with a simple state machine. You can do this by using one variable to act as a counter, and then incrementing that counter every program loop. With just simple if/else statements you can change the sate of several outputs and then reset your counter and await activation again.
If you are still stuck I'll post an example for you.
I'm crazy!
Unread 21-02-2006, 01:46
comwiz7's Avatar
AKA: Joey
I figured that out...I actually got it to work, but it works once and then not again. I made sure it was resetting the counters.
This is the code i wrote...
This is in the Default_Routine:
if(p1_sw_trig)
counter1++;
if(counter1 == 14)
shoot_level = 1;
counter1 = 0;
else if(!p1_sw_trig)
counter1 = 0;
if(shoot_level > 0)
shoot_level_runner();
shoot_level++;
printf("%d\n", shoot_level);
if(shoot_level == 61)
shoot_level = 0;
counter1 = 0;
This is the funtion it calls:
void shoot_level_runner(void)
if(shoot_level == 1)
relay4_rev = 1; // top ram out
if(shoot_level == 20)
relay3_fwd = 1; // bottom ram out
if(shoot_level == 40)
relay3_rev = 1; // bottom ram in
if(shoot_level == 60)
relay4_fwd = 1; // top ram in
Why does it only work once???
Unread 21-02-2006, 02:38
AKA: Goldfarb
From what I see you need to reset the state of the relays. Once they receive a value they will stay that way until that output is modified.
I'm crazy!
Unread 21-02-2006, 03:52
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
You have no logic to turn the relays off. You have to do a relay4_fwd = 0 when you set the reverse on, and so on.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 21-02-2006, 08:33
comwiz7's Avatar
AKA: Joey
Could somebody help me code that? I don't understand. What do I need to change?
Unread 21-02-2006, 09:38
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
I briefly read over your code, and I'm not exactly sure what you're trying to do. Explain what you want in words, and I'll try to help you out with your code.
Unread 21-02-2006, 09:47
comwiz7's Avatar
AKA: Joey
Basically we are controlling our feeding mechanism to our flywheels. We have 2 rams, an upper and a lower. By defualt, the lower ram is extended holding up a stack of balls. When we press the joystick trigger, we want to fire the top ram which will then hold up the stack of balls. Then retract the lower ram which will drop only one ball into the flywheels. Then extend the the lower ram again and then retract the top ram, so as the stack drops and we can repeat. Does that explain it?
Unread 21-02-2006, 11:22
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Shameless plug:
http://www.chiefdelphi.com/forums/sh...507#post455507
Those might make it easier to set up your relays, less confusing logic to deal with. It's a series of macros to set relays FWD, REV, and OFF, one-liners, saves some headaches.
Good luck!
Matt Krass
Unread 21-02-2006, 11:35
comwiz7's Avatar
AKA: Joey
Telling it what to do isn't the problem. It works fine except it only does it once, then it won't do it again. Also, when I do an if statement, like this:
if(counter3 == 1)
relay3_fwd = !relay3_fwd;
It always executes this statement, whether or not counter3 = 1. Even with a printf I found that counter3 was equal to 0 and it still executed this statement.
Unread 21-02-2006, 12:44
bush's Avatar
AKA: Aaron
Try this...
Declare/initialize these variables at the top of Default_Routine
static unsigned char shooting = 0;
static unsigned char counter1 = 0;
And add the following anywhere in the body of Default_Routine
if (p1_sw_trig) shooting = 1;
if (shooting)
	switch (counter1)
		case 0: //TOP RAM OUT
			relay4_fwd = 0;
			relay4_rev = 1;
			break;
		case 20: //BOTTOM RAM IN
			relay3_fwd = 1;
			relay3_rev = 0;
			break;
		case 40: //BOTTOM RAM OUT
			relay3_fwd = 0;
			relay3_rev = 1;
			break;
		case 60: //TOP RAM IN
			relay4_fwd = 1;
			relay4_rev = 0;
			shooting = 0;
			counter1 = 0;
			break;
		default:
			counter1++;
Unread 21-02-2006, 13:04
comwiz7's Avatar
AKA: Joey
I have already tried the exact same thing you are doing with this and surprisingly, it didn't work. But with lots of trys we finally found something that did:
if(!p4_sw_trig){
if(counter1 > 9 & counter1 < 61)
counter1++;
else if(counter1 < 10 || counter1 > 60)
counter1 = 0;
} else if(p4_sw_trig){
if(counter1 < 1000)
counter1++;
if(counter1 == 10)
relay4_fwd = !relay4_fwd;
if(counter1 == 30)
if(counter1 == 50)
if(counter1 == 60)
I don't know why this worked and that didn't but it works and I'm happy. Thanks, everybody, for helping out.
A few simple programming questions; Oumonkey Programming 18 17-02-2006 14:24
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Problems and questions about programming hedgehogger Programming 4 15-01-2005 18:18
Default mapping relay questions Jared Stofflett Programming 1 25-02-2004 19:06
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
