Go to Post Read the rules. And then read the rules again. Then, get together as a group and read the rules together. - Knufire [more]
Unread 21-02-2006, 15:19
Specialized's Avatar
Specialized Specialized is offline
Student-Parent Liason/I make stuff
AKA: Chris Riedinger
FRC #0195 (CyberKnights)
Specialized is a jewel in the roughSpecialized is a jewel in the roughSpecialized is a jewel in the rough
Send a message via AIM to Specialized
We fixed our roller, Let us know what you think!
http://www.team195.com/files/195roller.wmv
A quick resdeign of the FP transmissions overnight and now running with dual FPs on the roller, we're sure to not have the issue we saw at the UTC Invitational. We can now suck up 3+ balls at a time at over 12fps (FYI- thats the top of our second gear). Look for us at UTC NE and the Championship event.
Unread 21-02-2006, 15:22
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: We fixed our roller, Let us know what you think!
Wow, incredible
See ya in the finals!
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
All I can say is I hope those automatic counters work wonders because that’s one heck of a bot! Really good "suction" I might say. What belting did you use and where did you get them from?
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 21-02-2006, 15:26
The "belting" is a material called PolyCord. That would be a McMasterCarr Special. We cut the cord and welded it to 8% less length than the actual length desired. Then, we carefull stretched it over the rollers. That seam we melted together is supposed to be just as strong as the original material.
Unread 21-02-2006, 15:53
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Its actually small parts
Another thing that we fixed was the pressure point. At the UTC scrimmage, if anyone saw, we were constantly riding up and over balls. This happened because our pressure point was high up and very closer to the center of the ball. If we rocked the tiniest bit while driving, the balls would find their way under the bot. By adding a lower pressure point(diamond plate) we no longer have that problem. The next problem was, we couldn't go up the ramp with this low point. To fix it, we added a hinge so it moves out of the way. Finally, if you look when we are depositing balls, you can see that the diamond plate is pushed out, away from the base. The reason being, a pneumatic pushes the plate so the balls have an extra push into the goal as well as help us get up or down the ramp with that side forward.
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 21-02-2006, 22:38
AKA: Ben Gagne
FRC #0195
After watching this video, where do you think the shielding would need to be to abide with the rule. The only thing that confuses me is, the device works exactly the same as a gatherer and is allowed to touch robots but when it is running in the opposite direction it would be "unsafe" even though it no longer touches robots. (still running the same speed)
Unread 22-02-2006, 16:21
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
amazing... simply amazing.. 10 fold better than at the scrim...
this will be one of the top bots at UTC no doubt... if not the best in low goals...
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 22-02-2006, 17:29
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Hmm.. where'd ya get those fancy FP's??
Unread 22-02-2006, 17:32
Thanks 237 for donating your Fisher Price motors to us two years running. I know how much you love us.
I fixed the Codec problem BuddyB309 3D Animation and Competition 1 09-02-2006 00:12
Roller Prototype sdexp Robot Showcase 0 04-02-2006 22:41
VCU Regional Problems Basically Fixed SteveC116 3D Animation and Competition 9 08-03-2004 21:53
Winamp5 Beta Clark Gilbert Chit-Chat 21 17-12-2003 21:44
The page is fixed for sure this time!!! Eric Sanders General Forum 0 30-09-2001 21:45
