Go to Post FRC is not worth giving up your grades. - Gregor [more]
Unread 04-02-2006, 14:53
Ultima Ultima is offline
FRC #0369
Ultima will become famous soon enough
Improved IFI Wheels
Original IFI Wheel:
Modified IFI Wheel:
Close Up:
Unread 04-02-2006, 15:20
Billfred's Avatar
Billfred Billfred is offline
Re: Improved IFI Wheels
Looks interesting, but what do y'all aim to do with it?
Unread 04-02-2006, 16:47
FRC #0369
Basically it is meant to strenghten the integrity of the wheels.
Unread 05-02-2006, 03:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
By putting in a 5/8" bearing?
2001-2004: Team 100
2006-Present: Team 254
Unread 21-02-2006, 15:22
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I'm curious if anyone has had problems with these wheels? Our screws kept backing out even after loctite and good torques. They don't seem to handle the shear/vibration happening when getting torqued. They also seem to flex enough to cause chain misalignments under hard turns. Last night we had to take all the roller bearings out of them and make long brass bushings to go all the way through the wheels as our 3/8" shafts kept bending and we completely smashed the roller bearings in 1 wheel. So far this has solved the flexing problems but I don't like riding on brass bearings. I think They're a great idea, but their modularity may be a serious weakness. I hope I'm wrong and we're just having bad luck.
www.179swampthing.org
Unread 21-02-2006, 16:06
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
What Loctite did you use. If it was the blue (low strength) then yes they still back out, but they should be good with the red (high strength) loctite.
As for the wheels deforming and causing chain miss alignment we have never had that issue, even with hard turns.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 21-02-2006, 16:17
Billfred's Avatar
Seconded. Our kids put red Loctite in the wheels, and they've held up marvelously though rookie drivers and me writing "JVN is a dweeb!" on them. So far, we've only had one chain problem, and we've got that one about nailed.
Unread 21-02-2006, 16:23
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Just as soon as we got them out of the boxes, red Loctite (271?) was applied in copious amounts. A few hours later, we realized that we needed to get them apart to align the shafts in the bearing bores, and wasted most of an evening taking them apart again.
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
pic: Team 229's Anodized IFI Wheels Adrienne E. Extra Discussion 11 23-01-2006 17:55
Improved Mecanum Wheels techtiger1 Technical Discussion 23 08-10-2005 01:02
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
