Go to Post The sign of a mature community is not that everyone is nice and happy but that differring opinions can be expressed. -Joe Johnson - archiver [more]
Unread 21-02-2006, 15:01
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Innovations in Control
So, now that it's crated and shipped, what sort of cool new control systems have you guys developed?
Team 888:
2 Drivers-1 for picking up balls, 1 for shooting
Each driver has a customized handling configuration. Our ball-picker-upper driver has full speed, direct control of the motors with joysticks. Our shooter driver (me) has controls that improve small adjustments by controlling the rate of turning with a gyro instead of mapping joysticks to the drive motors.
Our feedback system includes voice recognition and synthesis to improve computer-to-driver interaction and a camera-view HUD (Heads Up Display).
The shooter-driver system also allows the driver use body position and range calculations to set the speed of our shooter without gyro or accelerometer sensors on the robot.
Sensor feedback on the robot will allow the bin system to detect the location of the balls and move them into position for firing. It can also detect if balls are getting jammed in the bin and can automatically activate the unjammer.
Please contact Team 888 or stop by our pit at Pittsburg, Annapolis, and Nationals.
Unread 21-02-2006, 15:07
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Innovations in Control
The camera-view HUD, is that sending video? If it is, that's not legal.
We have a fully automatic ranging and targeting system; I rewrote the camera handlers to speed everything up drastically.
We had an automated ball-finding vision system, but I couldn't use it because auto mode is so short
I wrote a dashboard that displays a lot of information on the status of the autonomous systems on the robot, and is incorporated into our control panel.
The second driver's job at this point is to babysit the automation, and take over in case of catastrophic failure.
Sine we have dual shooters, they are staggered in software using switches on the firing paddles.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 21-02-2006, 15:33
Billfred's Avatar
Billfred Billfred is offline
1293 is sticking with the tried-and-true two-drivers, two-joysticks technique. It works for us.
Then again, this year we are improving on our controls method in other areas. How so? All will be revealed in due time...
Unread 21-02-2006, 16:10
Umm Errr...
our 2 axis shooter gimbal is aimed autonomously using the CMU cam. The manipulator driver just presses the fire button. Of course, there is manual override.
1139 Alumni
Unread 21-02-2006, 17:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
2 drivers, 3 joysticks, and a random glowing red button which when put sunglasses over, prompts freshmen to sing "rudolph the red nosed reindeer".
Don't ask.
As for the bot, you'll have to wait till the vid or pic is released to see.
Unread 21-02-2006, 18:12
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
2 drivers 4 joysticks . .
stick 1: tank left(trigger halfs the speed for fine control)
stick 2: tank right(triger halfs the speed for fine controll)
stick 3: opperates the turret(triger does an auto lock, x axis allows for the operator to controll manualy, hat allows for manual controll of the camera)
stick 4: opperates the cannon(triger fires, thumb sets the speed to what the code tells you the speed should be at your distance, aux 1 turns the speed down, aux 2 turns the speed up, and when you take the y axis all the way to 0 it turns the canon off.)
the dashboard shows the speeds of the 2 drive moters(well pwm value really) weather the camera can see the target, weather the turret is locked, what the speed of the cannon i if your on offence or defence
while it seams complicated its actuly very intuitive . . most things on there are for manual overrides
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 21-02-2006, 18:18
coldabert's Avatar
The Dude
No the camera view is not sending any extra video other than the data that is transmitted over the serial port and through the dashboard
Unread 21-02-2006, 18:26
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Succesful goal tracking and scoring in Auto mode.
Custom PCB for LCD Display Panel and Vocal feedback to the subsystems operator.
Our OI Talks
Cool beans
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 21-02-2006, 18:33
Stuart's Avatar
#include coffee.h
ohh forgot the coolest thing . . during auto mode our dashboard shows a "startup sequence" eather the "Evangelion" active links start, or the "Big-O" ye not guilty start . . depending on the auto mode/mood we are in.
Unread 21-02-2006, 19:30
coldabert's Avatar
The Dude
Our OI Talks
Cool beans
What sort of stuff do you have on the PCB? and is your vocal feedback software based or a record playing chip?
Unread 21-02-2006, 20:27
Sachiel7's Avatar
AKA: Shayne Helms
Our PCB is more of a mainboard that hosts a 4x20 LCD panel and the Emic Text to Speech Module, being run off a BS2 microcontroller.
http://www.parallax.com/detail.asp?product_id=30006
And I've attached a snapshot of our PCB.
-=Sachiel7=-
Unread 21-02-2006, 20:40
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
862 will have two drivers using two unmodified PS2 controllers, of course those are hooked up to our PS2 / OI Adapter
Driver has control of the tank steering and the ball intake and output functions
Copiolet has control of the shooter and the feeders to and from the shooter, as well as the auto aim
Check it out at Great Lakes , Wisconsin, and the Championship
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 21-02-2006, 21:27
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
2 drivers, one drives, the other shoots and runs the rollers to pick up balls
We have a two stick drive.
A laptop with a dashboard program that shows us how fast the launch wheel is spinning, our battery voltage, the gear we are in (displayed by an 8-bit rabbit and an 8-bit turtle), and a crosshair so the camera doesn't have to do all of the aiming.
Unread 22-02-2006, 09:17
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Our team doesn't have very much in the way of driver inovations just a dual tank style joystick drive for the primary and a custom switchblock for the secondary driver to power the roller, "jock strap" and "Drop it Like its Hot" systems
KK4KQO
http://voltair.us
Unread 02-03-2006, 16:18
coldabert's Avatar
The Dude
Sounds like alot of teams are trying out new techniques with their control systems. Good luck to all and I hope you can get 2nd place at nationals (cause team 888 and our partners are obviously gonna pwn).
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 22-08-2005 12:53
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 12-06-2005 01:51
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
