Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
Unread 22-02-2006, 06:13
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
pic: Team 1388: Finished
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 22-02-2006, 06:14
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Re: pic: Team 1388: Finished
That is the coolest low goal bot I have seen so far!
How well does the sonar-sensor things work?
How much does the robot weigh in at?
Nice video too!
Unread 22-02-2006, 07:22
GaryVoshol's Avatar
Cogito ergo arbitro
How does the hopper extend?
Does anyone on your team own safety glasses?
Unread 22-02-2006, 09:37
Billfred's Avatar
Billfred Billfred is offline
That must be the smoothest low-goal robot I've seen to date.
Unread 22-02-2006, 10:28
FRC #0973 (GRR)
Nice video too!
Thanks
The sonar sensors work really well. It's actually programmed to display on the OI's readout how far away (in inches) you are from the wall/goal/object the sensor is seeing. After alot of trial and error with our door, we finally got it in the right spot to drop the door and dump the load.
Robot weighs in at 119.57lbs, w/o bumpers. Bumpers weigh 14.88lbs.
If you're refering to the top (with the black cloth), there is a steel cable that is looped around the inside of the bot at the top, which goes back to a window motor with a spool on it. At the beginning of the match, the spool is wound up, so the "wings" are basically closed, and fit into the size limit. Once the match starts, the drivers can reverse the spool, and the wings are pulled out (see the bungee cords? we actually started with springs, but we couldn't find the ones we wanted, and the ones we tried kept getting sprung.
As for safety glasses .. we don't wear them when we're programming If someone had a drill out, or any other power tool, they would be required to have safety glasses on .. or suffer the wrath of me (I'm actually pretty strict about it)
You can see it from a few more angles here.
2011: ???
Unread 22-02-2006, 10:44
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
Well, good explanation but im gona have to say that still...its not safe.
But anywho what is that big mouth looking thing in the back round?
Oh, nice movie. Really detailed.
Unread 22-02-2006, 16:14
Tim Arnold's Avatar
I don't know what "i_am_Doug" is talking about, but you have a freaking awesome robot.
Check out the videos on their website (btw, nice; very fast): http://www.eaglerobotics.com/video.php
The belt looks very fast and effective while not over-complicating things and if the autonomous works as well as you make it sound... you guys are set! Congratulations!
Good luck in the 2006 season!
Unread 22-02-2006, 17:02
thecheatdx thecheatdx is offline
AKA: Cameron Christensen
FRC #1388 (Eagle Robotics)
thecheatdx is on a distinguished road
I'm that big mouth looking thing in the background... Nice choice of picture Mike, thanks I was yawning, I swear.
Unread 22-02-2006, 22:05
Garth1388 Garth1388 is offline
AKA: Garrett
Garth1388 is an unknown quantity at this point
As for the autonomous, we have a program that will score all ten balls very consistently and another that gets them most of the time. There are also a number of defensive programs that are meant to disrupt the opponents' code. We even have one that dances to the Mexican Hat Dance. It's not very usefull, but it sure does help to ease some tension on those late programming nights. We might end up running it in the pits at the UC Davis regional.
"I know not with what means World War III will be fought, but World War IV will be fought with sticks and stones."
-Albert Einstein
Unread 22-02-2006, 22:08
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
AWESOME Robot
What did you use for bumpers?
Thanks
Unread 22-02-2006, 22:52
FRC #0973 (GRR)
Originally Posted by aksimhal
AWESOME Robot
Thanks
Pool noodles and Cordura.
As for the Mexican Hat dance, If I have time, I'll compress the video and post it.
2011: ???
Every team please read and respond! Info wanted for FIRST family tree development! Elgin Clock General Forum 99 12-01-2012 03:03
pic: Team 1501 finished robot Wayne Doenges Robot Showcase 11 31-03-2006 20:02
pic: Team 1100 Finished Robot Mike M. Robot Showcase 5 21-02-2006 22:13
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
