Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 22-02-2006, 10:28
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pic: Team 1388: Finished
Originally Posted by robosapien
That is the coolest low goal bot I have seen so far!
How well does the sonar-sensor things work?
How much does the robot weigh in at?
Nice video too!
Thanks
The sonar sensors work really well. It's actually programmed to display on the OI's readout how far away (in inches) you are from the wall/goal/object the sensor is seeing. After alot of trial and error with our door, we finally got it in the right spot to drop the door and dump the load.
Robot weighs in at 119.57lbs, w/o bumpers. Bumpers weigh 14.88lbs.
Originally Posted by GaryV1188
How does the hopper extend?
Does anyone on your team own safety glasses?
If you're refering to the top (with the black cloth), there is a steel cable that is looped around the inside of the bot at the top, which goes back to a window motor with a spool on it. At the beginning of the match, the spool is wound up, so the "wings" are basically closed, and fit into the size limit. Once the match starts, the drivers can reverse the spool, and the wings are pulled out (see the bungee cords? we actually started with springs, but we couldn't find the ones we wanted, and the ones we tried kept getting sprung.
As for safety glasses .. we don't wear them when we're programming If someone had a drill out, or any other power tool, they would be required to have safety glasses on .. or suffer the wrath of me (I'm actually pretty strict about it)
You can see it from a few more angles here.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Every team please read and respond! Info wanted for FIRST family tree development! Elgin Clock General Forum 99 12-01-2012 03:03
pic: Team 1501 finished robot Wayne Doenges Robot Showcase 11 31-03-2006 20:02
pic: Team 1100 Finished Robot Mike M. Robot Showcase 5 21-02-2006 22:13
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
