pic: Why 12 m/s is important.
Re: pic: Why 12 m/s is important.
lol.
I love how the wood cracks like glass. The properties of poof must be altering the wood at high velocities hardening the material into a diamond like structure and then causing it to crack!
If your shooter was REALLY good, the ball would have shot clean through the goal!
Those balls in the goal look like they've been through a meat grinder - I take it you guys got in lots of practice? |
It wasn't the practice that grinded them up, it was the prototyping. Some of our prototypes were based on meat grinder-style shooters.
Oops! sorry about that! wrong setting
#7
This begs the questions:
If a ball made it through the panel and is counted by the ball counter, does it still count for 3 points? What if, while going through, it broke into multiple pieces? Would each piece count for 3 pts? |
#9
From a careful reading of the rules, if the ball goes through the counter at the bottom of the goal mechanism, it's 3 points. An obvious strategy that I haven't heard on this board yet is to lob the balls over the top of the face of the goal into the bin on top. I'm surprised, &c. As for broken Poofs, I believe we hypothesized early in the build season that a fractional ball would have to retain the majority of the mass of the original ball to count. |
#10
(warning: Silly^2 Post)
is there anything in the rules that says your robot cant tack a string to the ball then toss it into the center goal, pull it back out toss it back in, pull it back out.... DING! DING! DING! DING! DING! ? |
#11
Yes, there is a rule to prevent it: Rule <G05> "In order for a ball to score, it must enter the goal and exit via the exit chute. A ball that bounces out of the goal is not scored. Once a ball is scored for a particular ALLIANCE, it cannot score again until it is entered onto the field by the opposing ALLIANCE’s HUMAN PLAYER. " So unless the opposing human player pulls on the string to pull the ball out of the goal, you can't get away with it. ![]() -dave |
#12
Not to mention entanglement! |
#13
i think its sharpied.
when have you seen cracked plywood with incredibly defined lines where it broke. (not to mention the fact that the cracks are much darker than the plywood) |
#14
This is why we just can't have nice plywood practice field elements!
I noticed you seem to have decent room to set up practice field elements there. Is that part of your school or space at one of your sponsors? |
| pic: 1018 - Pic 4 - Welded Chassis | Stu Bloom | Robot Showcase | 17 | 02-03-2006 09:36 PM |
| pic: River Rage 9 pic | JohnBoucher | Extra Discussion | 2 | 10-30-2005 02:43 PM |
| Using a computer to control the pic | mikesown | Programming | 6 | 09-13-2005 07:13 PM |
| PIC 18F2431 | Sparks333 | Programming | 9 | 08-24-2005 01:24 AM |
