Go to Post This year should be an unusual object game. You know what an unusual object is? Water. - TheBoulderite [more]
Unread 22-02-2006, 15:12
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
How'd you do it?
I've been working with the camera a bit throughout the season, it really perks my interest. None of the team wants it on there except me, so I am still pushing them to let me work on it.
How do you turn your robot to the light? We don't have a turret, so we need to turn the entire robot.
I've come up with two ideas:
1)you mount the camera so it can pivot on its own with the servos, then turn the robot until the camera is straight.
2) you mount the camera stationary (no servos), and turn the entire robot until you lock on.
We're only talking Pan here, not tilt.
Which do you think is the better idea?
The only way I can see to do it the first way, is to lock on, then move the robot a little, then lock on and move a little more until the camera is straight.
The second way, you move the entire robot in a search pattern which seems a tad 'dangerous' to me, especially with my lack of programming ability
On our robot, it would be a lot easier to mount the camera stationary (i've already got the spot picked out), but we would then need to move the robot itself in the search pattern. This would also make the tilt adjustment VERY easy, being a simple "run a motor until it lines up" to tilt our shoot angle. This is probably what I will end up doing if no one sees a problem in it
Looking forward to your opinions!
~Dave
team 706
Unread 22-02-2006, 15:17
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: How'd you do it?
We have the camera mounted stationary, and will use the relative position of the vision target in it's field of vision to aim the turret/launcher.
Unread 22-02-2006, 15:50
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Number 1 is the best way to do it becuase your not going to get the accuracy you need with having your robot pivoting around all the time. Its easier and more usefull to use a pan assembly and mount that on the robot.
Unread 22-02-2006, 17:39
Perhaps, but then how would I quickly move the robot and camera at the same time to get the robot straight to the target?
The only way I can see to do this is to move a little, re-track, and repeat.
Unread 22-02-2006, 17:41
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Just remember you are only allowed to work on software during the fix-it windows.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 22-02-2006, 17:43
The Lucas's Avatar
CaMOElot, it is a silly place
Mount it stationary, especially since you arent going to use tilt. The camera is going to have the target in its field of view if you are facing anywhere near direction of the target. Just get the median x (mx) near the center of the field of view and fire. The camera should only be a fine ajustment so no search routine. In auto mode just drive to about where you need to be and have the camera turn the bot a little bit to line up. Same thing in operator mode. Use an LED to indicate Target Locked and maybe a button the driver can push to do the same fine adjustment as auto mode. Just my $.02 Good Luck!
Robot Inspector
Unread 22-02-2006, 18:48
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Mine does it rather neatly, have the driver park it in range, then have him hit a button, if the robot sees the green light, it will auto adjust to the right angle, and then the driver can start shooting. It is great!
My Blog!
Unread 22-02-2006, 21:31
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
I have it so the camera is freely mounted, can do it's search routine, when the cam locks on, the driver can press a button and have the robot line up with the target, find the distance from the target, and adjust the speed of the launchers accordingly. It works pretty well!
www.sabrerobotics.com
Unread 22-02-2006, 21:34
This is exactly how our software team designed our shooting controls. Now if the mech team had only been able to finish it in time for testing before it went into the crate...
Unread 22-02-2006, 21:46
Denz's Avatar
Yes, the only problem is, when lining up the robot overshoots sometimes, and it kind of moves back and forth. This I am told is a PID problem, not sure what that means, and I'm a rookie programmer. Maybe if anyone has a solution, or can help me, I would really appreciate it . But yeah, I had to make many sacrifices because of the mech section. I had originally wanted a rotating turret, and angle adjusment on the turret, but none of these "luxuries" were avaiable, it still works really well though! I'm overall happy with it.
Unread 22-02-2006, 21:50
Oh, man, that hurts. The student head of software wrote a PID controller for the aiming process. Before that, ours hunted back and forth, too (tested on Wooden Thunder, we've never run the code on Top Gun. PID is hard -- it might take too long at this point, and if you don't have a really good mentor it might be impossible. John did test a PID-less version that worked pretty well, but it was S - L - O - W. Good luck.
Unread 22-02-2006, 21:52
Eldarion's Avatar
If you have a PID loop already in place, increase the D term to dampen the oscillations.
-- Thomas Paine
-- Anonymous
Unread 22-02-2006, 21:59
Denz's Avatar
I don't even know what a PID loop is?
I had something like this:
if (p1_sw_trig == 1)
if ((((int)PAN_SERVO - 131)>= 1)||(((int)PAN_SERVO - 131)<=-1))
RIGHT_W = (127+(12*(((int)PAN_SERVO - 131))));
LEFT_W = (127-(12*(((int)PAN_SERVO - 131))));
else
RIGHT_W = 127;
LEFT_W = 127;
I'm thinking maybe 12 is the D value, however, when I decrease it too much, the robot wont turn when it gets to the point of being servo steps off.
Unread 22-02-2006, 22:15
AKA: Bert JW Regeer
Mine was a rather simple one, if we were more than 20 pixels off target, we spun the wheels fast, as we got to 10 pixels, we spun them slower, until we got to where we wanted. Within the 10 range we get the most accurate shots, so after that no more adjusting. Works great on carpet, not so great on just normal floor, as the carpet gives a lot more resistance.
My Blog!
Imagery Award winners: How'd you do it? Billfred General Forum 5 05-01-2005 18:05
Windows XP - In My Hands Nate Smith Chit-Chat 15 01-08-2001 10:24
