Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 22-02-2006, 14:33
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
netting material
I am wondering what material people are using to hold in balls if they are at all. Also where I can find the material. We have tried a couple things and I don't particularly like any of them.
Unread 22-02-2006, 14:36
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Re: netting material
How about that stuff that they put at construction sites...you know, that orange safety net? The material is thick enough that screws won't pull out but it is kind of bulky and heavy.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Unread 22-02-2006, 14:40
Titan Robotics (492) is using the plastic wrap you put around the crate. Cheap, light, and easily replaced...
We used 1/16" Lexan.
Unread 22-02-2006, 14:55
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Our team is using a combination of 1/16th and 1/8th inch Lexan with the corrugated plastic material that is used in stuff like real estate and "For Sale" signs. If you have two layers of it that are going in perpendicular directions, it is fairly strong.
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Unread 22-02-2006, 15:30
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
177 is using .020" polycarbonate sheet available from McMaster and many other fine retailers. We have also used plastic window screen in the past.
Pete
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 22-02-2006, 16:55
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Uhm... Rick? That was our sad replacement because some one dropped the ball in purchasing! We have replaced our suran-rap with real stuff!
Also, the stuff they use on construction sites are nice, but VERY heavy.
Attached is the pic of our NEW hopper/backboard material.
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 22-02-2006, 17:37
I'm sorry to hear that. I was looking forward to you kicking big robot butt with a hopper covered in plastic fish wrap. Looking forward to seeing you in Portland...
Unread 22-02-2006, 18:42
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Screen door material. We use the pet proof stuff (it's coated in plastic).
Brian Graham
Unread 22-02-2006, 19:03
AKA: Erik Thulin
Hehe, but check it out! We gave Pengu (our penguin mascot) a scateboard! There is no way we could loose now!
Unread 22-02-2006, 20:37
SpaceBoy2000's Avatar
SpaceBoy2000 SpaceBoy2000 is offline
Guy with Hammer in CAD cabinet
AKA: Michael Kwan or Frogger
FRC #0610 (Coyotes)
SpaceBoy2000 is on a distinguished road
1/16" Lexan cheezed up with lots of holes and held together with tiny aluminum angles and rivets.
Unread 25-02-2006, 14:09
AKA: Sean
team 1002 had some really cool spandex net and were thinking of using that. Mainly because we can get it in pink.
Unread 25-02-2006, 14:13
Conor Ryan Conor Ryan is online now
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I'm pretty sure we used Deer Netting from Lowes, each square the netting has is about 1" square, its cheap, and available easily. But do keep in mind we didn't use it to hold balls, just to protect balls from getting into our robot in inappropriate places.
Just as a reconmendation though, if you can afford the weight I'd reconmend going with a solid polycarbonate like lexan. You don't want your nets to absorb the energy from the gravity and cause bridging, ideally you want the balls to bounce off the material and move as far down as possible, as a team that has tested it this year and used netting to hold balls in the past (04) we experinced a lot of jamming using nets. Lexan is harder so balls bounce off of it and move around more, netting is flexible and absorbs a lot of energy which leads to bridging and jamming. And even if you have something to break the jams, you've still lost time.
Unread 25-02-2006, 14:36
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Team 647 is using Winter Camouflage netting for its hopper. It is really strong stuff we had six team members trying to rip it at the same time and the netting did not rip. We got it from an army surplus store. (We live near Ft. Hood, there are a lot of army surplus stores around). You can see it here.
Unread 27-02-2006, 14:30
AKA: Sean
we would use lexan but we are at 119ish pounds right now.
Material help White_Orpheus 3D Animation and Competition 10 21-11-2005 10:58
Seeking Thermally Conductive Material Torchin Chit-Chat 0 25-01-2005 05:59
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
