| View Poll Results: do the side goal proximity rules affect your robot | |||
| yes |
1 | 3.70% |
| no |
17 | 62.96% |
| only if our driver messes up |
1 | 3.70% |
| side goal proximity rules? |
8 | 29.63% |
| Voters: 27. You may not vote on this poll | |||
goal proximity rule
i know that a rule states that the robots that go for the side goal have to stay outside 3 inches from the side goals
however in the scrimmages so far teams have broken this rule numerous times. does this fairly unknown rule affect your robot? ours has a door so it is important with ours. EDIT: this is rule G21 Last edited by gondorf : 22-02-2006 at 21:31. |
Re: goal proximity rule
<G21> ROBOT Incursion into the Corner Goal - Incidental incursion into the corner goal that occurs as a resultof a ROBOT pushing balls into the goal is permitted, not to exceed a distance of approximately 3 inches. Intentional incursion, for example to use a ball gathering mechanism to drop off balls inside the goal, or extending a portion of the ROBOT through the goal opening to activate the ball counting system, will result in disqualification of the offending ROBOT. this is a bad thing for some teams. please post your opinions |
having a door that the balls roll down is probably not considered incidental scince it is desined to go into that goal and drop the balls off to avoid the ramp |
You state: i know that a rule states that the robots that go for the side goal have to stay outside 3 inches from the side goals When really the rule is the bot may not go through, as in on the corral side, the goal by 3 inches. You get the difference? |
<G21> says that incidental incursion may not exceed 3 inches into the side goals. It does not establish a 3 inch exclusion zone outside the goal. A robot inserting an active ball delivery mechanism into the goal will be disqualified, but dropping a door onto the top of the goal ramp to prevent gravity from working against you isn't against the rule.
#7
R.T.M.F. Read The Manual First!
<G21> Has been there since kickoff. You can not incidently "enter" the goal any more then 3 inches. Though you should have designed the bot to not even enter the goal as there should be no need to do so. |
#8
| Midfield Collisions | Swampdude | General Forum | 36 | 31-01-2005 23:51 |
| YMTC: Is it goaltending? | Natchez | You Make The Call | 43 | 12-04-2004 18:03 |
| FIRST and Success: A Question of Definition | Madison | General Forum | 70 | 27-11-2002 08:42 |
| Small balls in 2001 competition | archiver | 2001 | 10 | 24-06-2002 03:59 |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 24-06-2002 03:13 |
